Question about Lands Phones
Bought new BT8500 phones (3). Can't get them to work. Handset says "line cord error" have checked all connections and when I plug my old phone into the same line it still works!!
Brand new Triple set
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
SOURCE: 5.8 ghz mulit-handset cordless phone
How do you get the ringer on this phone to work?
Posted on Dec 14, 2007
SOURCE: Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
Posted on Jan 21, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
BillB-SA
  • 2761 Answers
SOURCE: i have a Uniden dect6.0 cordless phone, when I
When the "check phone line" message appears, it is referring to telephone service and not the wire. It appears that your phone jack is "dead" or that there is no working service in the home. Do you have another phone that you can use to check the jack? Is there another jack that you can plug the phone into for a test?
Posted on Nov 21, 2009
I've just bought the above phone and connected tomains to charge batteries and handsets show "line chord error" is this because the phone line has yet to be plugged in?
yes, it will either show line cord error, or no line. After phone is charged plug line cord in and it should go away if not check line cord or try another known good cord.
Aug 11, 2015 | Lands Phones
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
AT&T Design Line Telephone 146 - static on line
Check the cord from the phone to the handset - wiggle both ends to see if you get more noise. Could be a bad connection or bad cord.
Jan 23, 2012 | AT&T 146 Corded Design Line Telephone
Just brought the phone charge for 2 days phone reads handset out of range,
First check if the battery is properly connected/installed. It's possible for the connection to be loose. If this is your situation, recharge the handset again. Then try again.
Next make sure that the base has power (plugged into a live outlet). With a regular corded phone, make sure that the phone line is working. (Make sure that you get a dial tone.)
If the unit is new, you may want to contact Uniden. The battery may have degraded over time in a warehouse. If you bought the unit used, try a new battery.
I hope this helps.
Aug 14, 2011 | Uniden Lands Phones
Humming on clarity phone. did not hum when first purchased. old at&t phone does not hum when plugged in on same line.
Have had this symptom from bad line cord or corroded line cord connection in phone. Also, could be bad handset cord. Try switching out the handset and handset cord from the AT&T phone to determine if Clarion has bad handset or handset cord.
Jan 23, 2011 | Clarity (76556) Corded Phone
Just brought a new Panasonic KX-T7330 phone, but not working (no sound at all) with plug in existing phone line plug. Used back the old phone with that phone line plug. that old phone is working normal....
It's pretty straightforward. We didn't get many 73xx phones installed in the U.S., but make sure you're using a 4 conductor line cord and see if it works on speakerphone. If it doesn't, it may have a headset/handset switch on the side or it may just be toast.
Carl
Aug 15, 2010 | Panasonic KX-T7730 Corded Phone
I bought a Uniden cordless phone, put the batteries in (it has 4 remote bases) and charged it for 20 hours as instructed. I tried calling it on my cell phone but I'm not getting s response. The display...
Double check that the telephone cord is firmly plugged into the back of the cordless phone base, the wall outlet, the outlet where the telephone modem is and at the L1/L2 jack on the back of the telephone modem. Your phone is not getting the dial tone line voltage from the telephone modem to the cordless base. There might be a short in the wiring. (It is unclear as to whether you are setting an old phone into this new base or swapping out and using another base with the old phone. Irregardless, the problem would seem to be not in the phone but ratther narrowed to the cord between phone modem and phone base. That is a very good reason to check how firmly the cord is plugged in.
Aug 27, 2017 | Lands Phones
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
Lands Phones Logo
1,391 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
