Question about LG 42PG20 42 in. Plasma HDTV
I have 2 vertical lines on my lg 42pg20 plasma hdtv
    Top Expert:
  • LG Master
  • 74,118 Answers
Check all the COF [Chip On Film] connection for any loose connection to its socket/s. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 16, 2014
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
SOURCE: the left side of my LG plasma has vertical lines.
It sounds to me like one or more of your buffer boards has gone bad. You will probably have to have it looked at.
Posted on Apr 07, 2009
gsalmen
  • 77 Answers
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
Posted on Jul 10, 2009
  • 280 Answers
SOURCE: I have a lg 50px1d 50
Sounds lik a bad buffer board. you will probably have to have a tech replace it.. could be big $$$. get an estimate first.
Posted on Oct 23, 2009
  • 668 Answers
SOURCE: I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Posted on Oct 25, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Lg 42PG20 possible to work on a 220 volts?
The correct answer is "it depends on the power supply board used in it".
If you click on the picture at
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
and look at the lower left corner of the board you will see
100v-240V
printed in the lower left corner.
That board used in 42PG20 will definitely work on 220V.
Your TV may have a different board inside though.
DO not assume...verify.
Hope this helps!
Jun 29, 2014 | LG 42PG20 42 in. Plasma HDTV
Orange bars flashing around the screen
This is a link for repairing the power supply board of a LG 42PG20, which also contains a link to an article on how to test the board's functionality, which is actually fairly simple:
May 16, 2013 | LG 42PG20 42 in. Plasma HDTV
I have a LG 42 inch plasma that turned off and doesnt want to turn back on. im thinking is the sensor is there anyone that can help out with this problem?
If you can turn it on with the button on the unit itself then it may be the IR sensor, but if you can't turn it on then it is very unlikely the sensor.
The power supply board of the 42PG20-UA is a known source of exactly this problem, although definitely not the only one that could possibly cause it.
Below is a link for a repair of the board, but the listing also contains a link to an article on how to test the power supply board alone, which is pretty useful before spending time and money sending it for repair. If anything you can rule one board out:
Nov 17, 2012 | LG 42PG20 42 in. Plasma HDTV
I have a LG 42PG20D with a one inch brite white stripe, going from top to bottom about 3/4 along the screen on the right side
That vertical stripe is not fixable in plasma TVs.
Well, easily 99% of them.
The reason is that what goes bad is actually embedded in the display itself and not subject to servicing or replacement.
1% , possibly less, of the plasma TVs out there have that part outside of the display and as such subject to replacement.
Sorry for the new and please do not kill the messenger!
Nov 09, 2012 | LG 42PG20 42 in. Plasma HDTV
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
Hope this helps!
May 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Vertical colouered lines on the right side of the screen...
If it looks like a pin or magic marker drawn straight down the screen, it most likely is a de-laminated flex cable to the glass, if it is the panel needs replaced.
Sep 01, 2009 | LG 42PG20 42 in. Plasma HDTV
Audio Problems
Did you try to lower the Bass level from the Sound menu?
Apr 12, 2009 | LG 42PG20 42 in. Plasma HDTV
LG 42PG20 42 in. Plasma HDTV Logo
Computer Repairing
Computer Repairing
