I have a titan ts133 remote start. The car starts but immediately stops when I start it remotely.
Titan ts133 remote starter. I tried doing a reset but it is still starting then shutting off immediately. Please help.
  • 1694 Answers
SOURCE: Pregramming my RCA Gemstar Video Plus remote with no codesearch button!
www.remotecodelist.com ........................................T.
Posted on Mar 22, 2008
  • 13 Answers
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Posted on Mar 30, 2008
  • 6 Answers
SOURCE: Valet 473T remote
It sounds like the system needs tach sensor reprogramming. The remote start system may have a tachometer sensing mode where the system "knows" that the car is running and to stop cranking the starter when when the engine is running. Generally when the vehicles battery is disconnected the system "forgets" the setting of the tachometer at idle which is programmed at the time if installation. Take it to a remote start installation store for this or get a hold of a maual for your system and shouldnt be too dificult to program.
Posted on Jul 10, 2008
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
  • 34 Answers
SOURCE: Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Posted on Jan 09, 2009
2008 Nissan titan would not when key is turned
Sounds like your battery is low or the starter is not engaging. Check the battery for 12 volts, then if it is still clicking but not starting, then all you have left is to take the starter off and have it tested free at autozone before you buy, to know for sure.
Feb 20, 2016 | 2008 Nissan Titan
A Nissan Titan v8 truck move very well but suddenly goes off snd will not start immediately untill it takes up to 5minute before it starts.pls can you pls help.
Possibly a fuel pump or fuel filter problem. A faulty pump can run for awhile, and then stop. If you keep turning the key on and off it might run again for some period of time, but eventually it will not run at all. On some cars and trucks you can hear the pump run when the key is in the start position. You could also have a blocked fuel filter.
Apr 27, 2015 | 2012 Nissan Titan S Crew Cab Pickup 5.6L...
2000 Titan Gecko how to replace the starter relay
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Titan, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Titan Gecko how to replace the starter relay Google Search
How to Replace Starter Relay YourMechanic Advice
http://www.eurologistyka.com/gecko_repair_manual_download.pdf Motorcycle Parts for Titan Motorcycle Co Gecko eBay
http://www.motorcyclespecs.co.za/bikes/Titan.htm
Sep 28, 2014 | 2000 Titan Gecko RM
Nissan titan truck wont start. positive
is the battery swollen on the sides or front(bulge) bulging batteries = dead cell
= new battery
Nov 07, 2009 | 2004 Nissan Titan
2004 Nissan would not start
Try checking your battery and or starter. If not them you might have another electrical problem.
Apr 29, 2009 | 2004 Nissan Titan
04 Titan Does not stay on when cranked
if veh have malfuntion ligth on may be is the cranck possition sensor or the cam sensor, olso if there is no codes
is the IPDM ir intelylled power distribution module veh will cut off when running
Mar 10, 2009 | 2005 Nissan Titan
Titan engine light
If you disconnect the battery for 1 minute the check engine light will reset itself and should go off. The only thing is that if there is a problem that the computer detects after you reconnect the battery and start it up , the check engine light will come back on. If it does the best thing to do is take it to a shop and have it checked for codes and see what is causing the problem.
Best of luck and let me know if this helps you.
Dec 27, 2008 | 2004 Nissan Titan
I had a Titan Remote Starter installed in my car, 2 years ago. The car starts and stops on its own, or the horn will beep and the lights will flash. Several times I've went outside on my way to work and...
Could be.
Yes, change the battery in the hand held unit first.
Next could be the control unit.
Next could be that there is something brocasting in the area that is near the same frequency.
Does this only happen at home? Or has it happened in other areas also?
Is this a factory unit? Or an aftermarket install?
Sep 06, 2008 | Oldsmobile Intrigue Cars & Trucks
Titan will not start
I think that you have a harness problem. Check the negative batt. cable to see if its tight on the engine. Clean any corrosion. I would check all the grounds in the engine compartment. Very common, for those to corrode and cause problems. There are whole bunch of those in the engine area. There is one under the battery tray also. Check the grounds under the windshield washer bottle. those also corrode and mess up your CAN system in the truck , resulting in no start condition. If you are 100% sure that your battery is good, than check all ground wires.
Jul 14, 2008 | 2006 Nissan Titan
Televison & Video Logo
Top Televison & Video Experts
