Question about Ovens
Does the red light on the bush ae6bfs stay on all the time?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
I had a look at the manual which I found here:
http://argos.scene7.com/is/content/Argos/4894827_R_D001pdf
and I don't think that the red light should be on all the time, depending upon the positioning of the function switches - see pages 9 & 10. You may wish to check the manual more thoroughly than I have to confirm this.
Cheers
Posted on Nov 15, 2014
My bush ae6bfs oven selector control switch burnt out for second time in one year???????
It should be under warranty if fitted by a competent service centre.
Oct 12, 2017 | Ovens
I need a wiring diagram for bush oven switch ae6bfs
Request the diagram directly from Bush.
Jun 05, 2016 | Ovens
Bush oven manual AE6BFS
Hi Eugene,
Download the manual on the link below.
May 08, 2014 | Ovens
How do I light the pilot light on an old moffatt oven
iT SHOULD TELL YOU ON THE BOX WHERE THE RED BOTTON IS LOCATED. MOST WORK LLIKE THIS. YOU TURN THE DIAL TO PIOLT AND HOLD DOWN THE RED BOTTON AS YOU LIGHT THE POILT CONTENUE TO HOLD BOTTON DOWN FOR ABOUT A MINUTE AND LET GO IF THE POILT STAYS LIT THEN TURN DIAL TO ON. IF POILT DOES NOT STAY LET WAIT FIVE MINUTES AND TRY IT OVER AGAIN FROM BEGINNING
May 06, 2014 | Ovens
Red light on stove stays on even when the burner is off
One of the switches has a short causing the light to stay on. Replacing the switch is the only way to correct the condition.
Sep 10, 2013 | Stoves Ovens
Does the bush AE6BFS single fan oven require hardwiring or can it plug into normal socket
Generally speaking, a single oven can be used from a normal 13 amp socket.
If you are not sure, check the power used by the oven on the rating plate, as long as it does not exceed 3kw, then itt is o/k to use from socket.
If more than 3kw, then it will need to be hard wired.
Oct 25, 2010 | General Ovens
I ran out of propane...so now truck is filling us up..how do I get the oven working again..how to light the pilot light?
Hi there, hope this helps. On the front of the oven, usually on the left side, where your thermostat is, has a red button sticking out, that is your pilot safety. To light it, you need to open the lower door, and aprox. in the center of the area, is your pilot, has a small pipe going to it, you have to hold the red button in, and light the pilot in that lower chamber, and most of the time, once the pilot is lit, you must hold the button for 60 to 90 seconds. If it does not stay lit when you let go of tthe button, you may have additional problems, let us know. And thank you.
Feb 20, 2009 | Bakers Pride Y-600 Gas Single Oven
Pilot light
When you smell gas...is it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
107 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
