Question about Air Tools & Compressors
I Have a CP oiless 2HP 8 gal Compressor that just quit. Plugged it in without extension cord. Took out plug and alot of moist rusty air came out. Any hope for this Compressor?
    Problem Solver:
  • 18 Answers
Buy another one, the two gallon one are very cheap.
Posted on Nov 15, 2014
Testimonial: "Thanks"
3 Suggested Answers
  • 5 Answers
SOURCE: my sears 2hp 15 gal compressor runs but pressure wont exceed 60lb
compresors pump, valvs or sels gon!
Posted on Jul 15, 2009
  • 59 Answers
SOURCE: I have a small central pneumatic air compressor it
Most of the time the air flow rating for the air tools you are trying to use are rated higher than your unit, Check the lable on the tools and compare to your compressor, otherwise you have have some type of restriction in the air line or within the tool itself. Hope this helps.
Posted on Nov 08, 2009
I have a 5 hp compressor. It will turn on and run maybe 5 seconds and then kicks my breaker out.
you could have a weak breaker or the breaker is not rated for the draw of the compressor have a pro check it out
Mar 02, 2015 | Campbell Hausfeld WL6502 5-Hp 20-gallon...
Air compressor will not restart after it builds pressure and pressure drops to 80 psi
Make sure the power cord is plugged into an adequate extension cord if one must be used. Never less than 12 gauge wire.
The start/run capacitor may need to be replaced.. If there are any ball check type valves, make sure they are not worn or sticking. they would be on the output of the compressor head itself.
Dec 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have a D55155 Dewalt air compressor. When I flick the switch to on the compressor sounds like it is starting very weak and then dies. A couple seconds later it repeats. Anyone know what this could be?
Yep! 2hp compressors need a strong power source. They'll draw alot of amps on initial startup. If they aren't getting sufficient power,they'll act just like this. It's causing the compressor's circuit breaker to cut out. Then when it cools off, it'll reset.
My suggestion is to avoid using extension cords if at all possible. The longer the cord, the harder it will be to start.
Try to plug directly into an outlet. If you need extension cords, use the shortest length possible. Also make sure the wire guage in your extension cords are no smaller than a 12guage wire(the higher the number, the smaller the wire guage).
Jan 02, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Aug 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am missing the screw in drain plug for a Model 95386 air comp.
this is normal item at parts house, anyway why do have a plug. i put a small ball valve much better i got at home depot
Jul 02, 2009 | Air Tools & Compressors
Air compressor won't stay running even with resetting
How quickly does it shut off? Is it reaching the turn off psi? or is it immediate.
If it is immediate then it is probably a power supply issue.
Air compressors are power hogs. For instance, a compressor may work fine on an outlet using the supplied power cord, but plug it into an extension cord that is insufficient for it and a repeat of your problem will occur. If you use an extension cord make sure it is made just for this kind of application. Also, if possible, give the compressor a dedicated circuit.
Another problem might be your unloader valve not working correctly. This reliefs the pressure inside the pump after the motor has stopped. it would sound like the pump is working extra hard at start-up.
May 19, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
My compessor wont start.
ALWAYS USE LARGE GAUGE CORDS FOR COMPRESSORS. LOOK FOR RESET BUTTONS OR THERMAL OVERLOAD BUTTON ON MOTOR. DID IT TRIP BREAKER OR GFI OUTLET?
Feb 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
69 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
