Question about Maytag MER6872BAS Gemini Electric Kitchen Range
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 650 Answers
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Posted on Nov 22, 2014
SOURCE: Gemini MER6769BAW Range/Dual Ovens
depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
Posted on May 15, 2008
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
jsrock516
  • 5911 Answers
SOURCE: when you turn oven on only the heating element
You may have a simple problem of a defective igniter. The following link explains a little theory about igniters and how to access the them on a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. Just because an igniter glows, does not mean it is good. If the igniter is weak, the gas safety valve will not open and gas will not flow.
NOTE: If BOTH manifolds were experiencing the same problem, you would potentially have had a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
A replacement igniter for your range can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the part number for a replacement igniter is 74007498. The part should also come complete with installation instructions.
If you require additional assistance, please let me know. If your model number is different, please post back with a COMPLETE model number (usually located on a nameplate around the oven door, or lower drawer opening) so that I may assist you further. Some manufacturers place the model number on the back of the operator console.
I hope this is helpful to you.
Posted on Nov 25, 2009
  • 713 Answers
SOURCE: Have a Maytag MER5730 oven and the oven stopped
your element is bad replace element.
Posted on Feb 13, 2011
oldTech2332
  • 2341 Answers
SOURCE: preheats very slowly. Also, steam cleaning option
For the oven their is 2 elements 1 for bake and 1 for broil,are each glowing red hot on the respictive settings of bake and broil? their is no trird hidden element. Plus i know manufactures come out with new features all the time,i attend factory trainging sessions a couple times a year but i am confused as to what the "STEAM CLEAN OPTION" IS??
THE SELF CLEAN cycle utilizes both elements to clean the oven adding steam is a new one on me
Posted on Aug 21, 2011
Should the heating element on my oven be entirely red ? 80 % turns red right now.
it sounds like the heating element you bought is damaged or burnt out.
return it for an exchange
May 03, 2012 | Jenn-Air Ovens
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Electric oven tripped my electricity a day ago and now the fan oven just blows out cold air
It is most likely that the oven heating element has failed. You will need to have it replaced
Normally the heating element is located around the circumference of the fan assembly and when it is working it glows red. You would see it if it was on.
Jan 11, 2010 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Constantly burning food, heating element in lower oven glowin red
You have a bad thermostat if the element never cycles off.
Feb 22, 2009 | Ovens
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
OVEN DOES NOT FULLY HEAT
assuming that we are talking about an electric range, lower element not glowing, you can check the element for continuity, froim behind. its either pass or fail. beaware to shut off power wires live all the time
Nov 16, 2008 | Whirlpool Ovens
Maytag MER6872BAS Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
