Question about Sharp Shift3 Lookbook Wireless Reader
<!-- from fixya rte -->Can not log in to account - Sharp Shift3 Lookbook Wireless Reader
  • Mark Mc Nov 15, 2014
    Hi john fellmer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Which account?
To register the account, do you use your Amazon account password? Old Kindle account password? email password?
If you are registering a new device. You have to give it your log in info for amazon account meaning user name and password you use when logging into amazon.com
Dec 02, 2016 | Amazon Kindle
How do I log into google
oh no come on its so simple to log into google go to your web browser type google in that web search Enter your Google Account username and password. If a username is already filled in and you need to sign in to a different account, click Sign in with a different account. If you see a page describing G mail instead of the sign-in page, click Sign in in the top right corner of the page. follwow this will help you https://accounts.google.com/SignUp
Google
Oct 04, 2016 | Tablets & eReaders
Can someone else log into their facebook account using my kindle fire hd
Carole, Yes, some one else could log into there account, if your account is logged out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do use my facebook account on someone elses tablet Face
How can access my Facebook account using someone else comput
Help Center
Aug 22, 2016 | Amazon Kindle Fire HD
How do I open my other Facebook account?
when logged in to facebook, select upper right triangle down, find log out, and log out.
then you can sign in again, with your other email address, you will need that. you can reset password if you need to.
you can do this to switch between the 2 accounts. if you don't want an account, log in, then
choose the padlock upper right , then More settings. on the left, choose security. In middle of screen at bottom, you should see deactivate my account. choose edit on the left.
Oct 05, 2015 | Insignia - Flex 8 inch Tablet with 8GB...
Galaxy tablet. How can I remove my husband's facebook account?
Open the Facebook app, open the settings, and choose "log out" to allow you to then log into your own account.
If you struggle with this, delete the app and download it again fresh. Then, log in.
Oct 01, 2015 | Samsung Tablets & eReaders
How do we log into a different person's fb account on this iPad?
it may be like a phone once you have set up an account to sign into it automatically stores that 1, so u would need to set up another log in account manually & then when u attempt to log in it will ask which 1 u want, if you cant set up more than 1 account, then u have to manually delete yours & then use his.
Apr 04, 2015 | Apple iPad Mini
Why can't I use two Facebook accounts on my tablet
The FB app is tied to the account used to login; to share the tablet, but not your accounts via the app, you may always need to log-out of the account. Alternatively, you may search for 3rd party FB apps that handle more than one account. Hootlet and Friendcaster are two of several 3rd party apps that can manage/handle multiple FB accounts.
Sep 23, 2014 | Samsung Tab Tablets & eReaders
After factory reset of my kobo glo, I couldn't get back my books that I ?
First make sure your books are really (still) in your account. Log into Kobobooks.com and check your library. Here's a direct link to the library page: Sign in to Kobo with
If you don't see your books there, you didn't buy them under that user account, or they're been removed from your account. Call Kobo support in either case.
If the books are there, make sure your Kobo eReader is also logged in using the same account. To do that,
1 - Open the menu
2 - Tap Settings
3 - Tap Account
Under 'Signed in as', you should see your user account. If not, tap in Sign in and log in. After that you can sync your library with your Kobobooks.com account from the menu again.
Dec 18, 2013 | Kobo Glo eReader Silver - N613-KBO-S
How do i login on as administrator on my computer?
Login With the Administrator Account in Windows XP Professional
Click the "Start" menu and then click "Log Off."
Click "Switch User" when the prompt screen opens.
Press "Ctrl," "Alt" and "Delete."
Click on "Administrator" when the "Log on to Windows" screen pops up. Type in the administrator password, if applicable.
Click "OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and allow it to continue through its startup process. By default your computer will simply load directly to the primary user account (usually the administrator account), but if there are multiple users on the system it will load to the account login screen.
Use the mouse to click on the administrator account from the list of available accounts to log on. This step is only necessary if you've customized Windows Vista with more than one account or you have set the operating system to load the login screen first.
Enter the password required in the password field to log on to the administrator account.
Click the "OK" or "Log On" button once you have entered the password. This button may be labeled differently depending on the version of Windows Vista or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows Vista environment by clicking on "Start" and then "Log Off." As soon as you have logged off, you will be returned to the login screen where you can choose the administrator account from the available list.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Compaq tc4200 Tablet PC
Sharp Shift3 Lookbook Wireless Reader Logo
27 people viewed this question
Top Sharp Tablets & eReaders Experts
Colin Stickland
Colin Stickland
Are you a Sharp Tablet and eReader Expert? Answer questions, earn points and help others
