Please HELP!
SOURCE: Printer won't print on my MacBook
Mine won't print from PC. checked everythong, re-installed drivers, got new ones... nothing, ...yes even formated the pc. but nothing.. unless i connect it to my canon s5 cam.... then the &"¤?& thing works....
SOURCE: Canon Image Class MF4150 Drivers
pls i want to copy for cd the driver about the photocopier ( canon multi function 4150) to install to the pc
SOURCE: Canon Pixma MX700 Scanner Problem
I was having the same problem, and thanks to the person who posted solution number two which simply highlighted the fact that the apparently software that came with the Canon Pixma MX700 unit is not compatible with Window Vista.
The reason I was confused is because the printer was working perfectly fine across the network, but when I went to scan my computer would tell me that it can't communicate with the scanner. I'm thinking ... "well since you can communicate with the printer, you should be able to communicate with the scanner, after all, they're the same device!"
As a workaround, I used a third party program to do the scan (in this case, Photoshop) and everything worked fine. If you have Photoshop, just go to file > import to start the scan. If you don't have Photoshop, I would think whatever program you are using for image editing may have the same functionality.
Hope that helps,
Brian
SOURCE: installation failure, canon pixma ip 1600 driver mcd 1.0
I have a windows vista and don't know why a cannot install my printer wich is a canonPixma i1600.Can you give any help.Thank you.
SOURCE: Scanning probelm with my MP810
May be MP Navigator not compatible with Kaspersky 2009.
If you use KIS or KAS to protect your computer,disable KIS/KAS protection and try again.
I have same problem with my MP150 and after disable protection of my KIS2009, MP Navigator work perfectly.
Sorry for my bad English. I'm Vietnamese.
