When i scan over than 40 pages whith document feeder of my copier(ar-4501 u) say memory full how can i fix it. i whant scan with it over than 100 or 200 pages
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
The memory on your copier will only store 40 pages. Depending on the type of copier, you might be able to upgrade the memory. Also, you might be able to use the memory on your computer to store the documents, but this again depends on the make and model.
Posted on Nov 16, 2014
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    • 19 Answers
    SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
    Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
    Posted on Jun 18, 2009
    • 118 Answers
    SOURCE: U2-40 error on Sharp AR 5127 copier
    try this pres the ff: # >interrupt> C >Interrupt
    input 16 then follow instruction
    this is related when you install not original toner or not compatible one
    Posted on Jul 21, 2009
    SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
    Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
    Posted on Nov 11, 2009
    Canon imageclass D1120 printer says: feeder paper jam,
    Hi Try this method
    To "Settings/Registration Table"
    You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
    For information on the optional products required to use this function, see "Optional Products Required for Each Function."
    1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
    1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
    Details of each item are shown below.
    [From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
    Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
    Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
    Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
    Mar 19, 2011 | Sharp AR-M237 Copier
    Sharp fax machine UX30 memory is full. How to empty fully?
    If the memory becomes full while the document is being scanned, MEMORY IS FULL will appear in the display. This may occur during fax reception if too much data is received before the pages can be printed out.
    1. Press these keys: (function) 6 # #
    2. The display will show: RECEPTION RATIO
    3. Press 1 to turn automatic reduction on.
    4. Select the reception ratio to be used in the event that the memory becomes full (automatic reduction is not possible when the memory is full). Press 1 for 93% or 2 for 100%.
    5. Press the STOP key.
    If you are attempting to transmit from memory:
    1. Press the START/MEMORY key if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder.
    2. After transmission, the memory will be cleared and you can transmit the remaining pages.
    3. You will also need to transmit the page which was being scanned when the memory filled up.
    4. Press the STOP key if you want to cancel the entire transmission.
    Here is a copy of the User Manual for the Sharp UX30:
    http://www.docshare.com/doc/227849/Sharp-UX30-User-Manual
    Jun 30, 2010 | Computers & Internet
    Dark, vertical stripe on copy on Sharp AR-M160
    Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
    Feb 10, 2010 | Sharp AR-M160 Laser Printer
    Sep 18, 2009 | Brother MFC-7820N Laser Printer
    Not scanning full page
    You omitted some details which might help diagnose the problem. For example, are you using the document feeder or the flatbed? Anyway, I'll take a guess here.
    Check your paper size setting and make sure it matches the sheet you are scanning. (Letter, A4, Legal, etc.)
    If this is not it, then try scanning from both flatbed and feeder and see if results vary. Note that when you use the feeder, scanning is done in a smaller window to the left of the flatbed, so make sure that is clean.
    Mar 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    I can't use Print function for ByPass or Document Feeder?
    The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
    Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
    Scanning documents
    Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
    Thanks J
    Jan 24, 2008 | Sharp AL-1551 Laser Printer
    Scanning in colour
    Who and where do you get the idea that you should be able to, to scan in colour you need a colour scanner, yours is not it has a greyscale scanner only.
    This machine has a scanning kit option but that is not colour see specs below.
    AR-NS2 Network Scanning Kit (optional) 4
    Type:
    Flat bed monochrome scanning system
    Original Feed System: Platen/document feeder, simplex/duplex with RSPF feeds up to 39 opm
    Resolution:
    200 dpi, 300 dpi, 600 dpi
    Image Format:
    TIFF 6.0, ITU-T G3/G4 TIFF, G3/G4 single/multi-page PDF
    Scan Destinations:
    E-mail, Desktop, FTP, URL
    Destination Profiles:
    Up to 200
    Operating System:
    Windows 95/98/ME, 2000, XP
    Network Protocols:
    TCP/IP (includes SMTP, LDAP, FTP)
    Network Security:
    E-mail server user authentication
    Software:
    Sharpdesk Document Management Software (included)
    Link to brochere of the AR-M 237 GREYSCALE copier
    Jan 10, 2008 | Sharp AR-M237 Copier
    130 people viewed this question
    k24674
    jasbo
    jasbo
