Question about Home
<!-- from fixya rte -->How o I reset outside temperatre - Home
Why does my Igloo FRW700 my wine cooler always cool to 0 Celsius or 32F if you prefer regardless of the temperatre setting?
It may be possible your unit does not have an actual thermostat to control temperature. If you received a wiring diagram with your unit look to see if there is an actual thermostat in the wiring. Sometimes the wiring diagram is glued to the back of the unit.
May 20, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Fan comes on; however, can't get the desired temperature to set. I select it and two seconds later it shows a higher temperature.
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Sep 03, 2013 | DeLonghi CF210 Portable Air Conditioner
98 s10 2.2L Charging Issues, cleaned grounds and terminals, alternator and battery checked out fine, ran a code scanner..nothing showed up. it will hold 14v + and when it gets to operating temperatre it...
What process did you use to check alternator ? Ive always taken it in to auto store to have it tested.. I don't recommend it but when its running you can disconnect battery terminals + from battery and if vehicle stalls out then its for sure alternator..
Apr 28, 2013 | Cars & Trucks
Battery wont stay charging, cleaned grounds and terminals, alternator and battery checked out fine, ran a code scanner..nothing showed up. it will hold 14v + and when it gets to operating temperatre i
Need my dirty hands under the bonnet here to be honest but i would suspect a faulty diode in the alternator ,when it gets hot is shorting out allowing the current earth out but i could be wrong
Whirlpool electric solid element range model RS677PXV. The oven does not seem to heat over 250 degrees. What is the possible fix?
1. Pull the oven temperatre control knob straight off. 2. Loosen the locking screw. (note the position of the notches) 3. To raise the tempature, move the tooth a notch closer to HI. Each notch equals about 10F (5C). (Tighten the locking screw and replace the control knob.
If this doesnt increase the temperature of your oven you may need to look replacing the heating element.
Hope this helps.
Feb 13, 2011 | Whirlpool Kitchen Ranges
What does check gauge on a 2002 jeep grand cherokee mean?
it means you have a out of safe range measuring on 1 of your gages usually temperatre is high or low oil pressure or not charging
Jul 18, 2010 | 2001 Jeep Grand Cherokee
It is over heating and i can't find the temperatre gauge under the hood...
first of all check the radiator for leak or blockage. make sure the coolant is fresh. follow th eupper radiator hosr to the emgine block. there should be 3 bolts attached the themostat housing. take the themostat out and put it with hot water, maks sure the opens. the temperture sending unit should be directly under the themostat. msot likely the themostat is cause or the problem. unless the temperture gage is not reading correctly.
Jun 09, 2009 | 1998 Mercury Mystique
My frigidaire is not cooling
if able unplug for aout 3 minutes then plug back in (it should reset control unit) this should help
Jun 01, 2009 | Frigidaire FRS26R4A Side by Side...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
