Question about Welding Tools
My mastercraft ark hobby welder turns on but won't ark . The overload light is not on
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Could be a problem with the ground connection.
Posted on Nov 15, 2014
  • Robert Ellis Nov 15, 2014
    Yeah that all looks good the welder is not ampping up . It dousnt have a fuse on it or enything
  • Bob Brad Nov 22, 2014
    the tip and wire might be touching / shorted
5 Suggested Answers
luxur4
  • 92 Answers
SOURCE: welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Posted on Jan 23, 2009
  • 81 Answers
SOURCE: will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
Posted on May 05, 2010
SOURCE: mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Posted on Aug 17, 2011
luis_david
  • 407 Answers
SOURCE: Have a ground and wire is running but will ark intermited
There are two items I would like you to do:
1) Change your contact tip and try again. Make sure the wire is running smooth thru the gun. If this not cure the problem then go to step two.2) Change your wire. If it is too old probably is rusted and not making proper contact.Hope this help.
Posted on Nov 30, 2011
I have a mastercraft arc welder that turns on but won't arc the overload light is not on or enything
I'm not familiar with this model and I don't know it's age, but as a general check item on any welder, make sure your welding leads are in good shape and that your earth clamp is actually connecting to it's lead. They can burn and tarnish with use and fail to connect. Check likewise the lead connection into the electrode holder. Check their attachment to the welder unit too. There may be a thermal overload protection fuse/device/switch inside the unit which may need to be reset/replaced if you've worked it heavily recently.
If the welder is TOTALLY silent when you switch it on, it may indicate a transformer failure for some reason, usually there is a little bit of buzz or hum. Within safe limits (bear in mind there are dangerous high voltages inside the welder) you might use a simple multi-meter to check that you are getting transmission of power from A to B throughout the unit to the work piece, and that you've got adequate voltage arriving at the work. More safely, with input power totally switched off and unplugged, you can use a multi-meter to check continuity of circuits through the welder to make sure there isn't a break in connection somewhere from a component fault or failure.
Nov 15, 2014 | Garden
My mastercraft ark welder turns on but won't ark the overload switch is not on
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
Welder turns on but won't ark
If won't arc, then the feed is not moving the wire because the trigger button is not making a connection. Bad trigger. If the wire does feed, then your cable connection is responsible and needs cleaned and tightened.
Nov 15, 2014 | Welding Tools
Nov 30, 2011 | Welding Tools
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Will feed wire but will not start an ark to weld
May 04, 2010 | Hobart 500526 Handler 210 Professional...
Ark blow and like a loud ark only sometimes on 305
need to change your polarity or change location of your ground on the peice you are working on if running left to right put ground on right
Dec 14, 2009 | Lincoln Electric Ranger 305D K1727-2...
Welder feeding or arking
Jan 18, 2009 | Welding Tools
Manual for a Cambell Husfeld welder Model WF2000
You can download PDF versions of the manuals for CH welders at the Campbell Hausfeld website.
Look on the left under the Service Center heading for a link to manuals.
Rank this answer if you found it useful,
Carl
Sep 20, 2008 | Welding Tools
Welding Tools Logo
96 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
