Question about Garden
My mastercraft ark welder turns on but won't ark the overload switch is not on
  • 2,210 Answers
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
Posted on Nov 15, 2014
  • Robert Ellis Nov 15, 2014
    It is an arc welder . The switch lights up when you turn it on but it is not ampping up and I am not getting an arc
I have a mastercraft arc welder that turns on but won't arc the overload light is not on or enything
I'm not familiar with this model and I don't know it's age, but as a general check item on any welder, make sure your welding leads are in good shape and that your earth clamp is actually connecting to it's lead. They can burn and tarnish with use and fail to connect. Check likewise the lead connection into the electrode holder. Check their attachment to the welder unit too. There may be a thermal overload protection fuse/device/switch inside the unit which may need to be reset/replaced if you've worked it heavily recently.
If the welder is TOTALLY silent when you switch it on, it may indicate a transformer failure for some reason, usually there is a little bit of buzz or hum. Within safe limits (bear in mind there are dangerous high voltages inside the welder) you might use a simple multi-meter to check that you are getting transmission of power from A to B throughout the unit to the work piece, and that you've got adequate voltage arriving at the work. More safely, with input power totally switched off and unplugged, you can use a multi-meter to check continuity of circuits through the welder to make sure there isn't a break in connection somewhere from a component fault or failure.
Nov 15, 2014 | Garden
Will my century 230 ark/tig welder switch from ac to dc
Your question is not clear, but if it is, your welder should have an handle to switch from dc+to dc- and ac, it wont do it on its own
Sep 23, 2014 | Welding Tools
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Ark blow and like a loud ark only sometimes on 305
need to change your polarity or change location of your ground on the peice you are working on if running left to right put ground on right
Dec 14, 2009 | Lincoln Electric Ranger 305D K1727-2...
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Aug 30, 2008 | Miller Electric Mfg Co 903505 Invision...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
