Question about NAD T760
I have a Nad T760 receiver/amp (not sure what the difference is). The remote cannot function. Is there a universal remote that I can buy? As this is quite an old piece of kit not sure if there is a
The remote is no longer functioning and there are many features that can only be controlled through the amp. I have heard of something called 'learning remotes' but how will they learn if they can't be trained???
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Some remotes can be programmed by entering a manufacturers code using the numeric keys. i use a Sony RM-VLZ620 remote. it lists NAD as a supported receiver.
P.S. - a receiver is an amplifier with a built in radio tuner.
Posted on Nov 15, 2014
3 Suggested Answers
SOURCE: Remote control not working
This was fixed by myself, the IR receiver was dead, replaced with a good one, working fine now.
Posted on May 20, 2008
ziraffa
  • 827 Answers
SOURCE: NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Posted on Dec 20, 2008
NAD T754
Sometimes manufacturers change codes from time to time and functions that the remote controlled yeasterday can't be controlled today. You might be able to get some functionality out of another universal remote with a more extensive library of codes available. I understand your frustration - I have a bunch of useless remotes as proof.
Dec 10, 2013 | Audio Players & Recorders
How to set up nad t760 receiver to 42inch lcd tv what leads and where they go receiver has no rdmi
Sorry I am not sure what you mean- Icelandic is my first language, please explain.
all the best
kolla
Feb 16, 2012 | Televison & Video
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
The unit will not stay on
I got similar issue and managed to fix it with excellent tech support from NAD. Flashing LED means system goes in to protective mode. Most probable reason is presence of DC voltage on amplifier out puts. In my case it was both surround amps. It had faulty resistor and a dry jpint at power line
Dec 16, 2009 | NAD T760
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
NAD
575 773 975
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
How to set up a logitech universal remote with a divinci ampifier
I had the same problem with a universal remote and my NAD i contacted logitech and they said if i send them the universal remote plus the details of the NAD they run another programme to allow it to sinc up.Good Luck
Jul 10, 2008 | Audio Players & Recorders
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
DTS - no sub output
Did you go into the sub-menu to see if the NAD sub output is turned on?
Apr 14, 2007 | NAD T760
NAD T760 Logo
166 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
