Question about Pentair Master Temp 400K BTU Natural Gas Heater Low Nox ASME 460775
Clean corroded thermastat
Trermastat plunger is corroded will not move
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
I think you mean the thermal regulator the one in the manifold where the water plumbing is if its corroded it is a water chemistry issue the part is an easy fix but check your water
Posted on Dec 10, 2014
  • Pentair Master
  • 1,631 Answers
What is a thermostat plunger?
If anything is corroded, Thermister or Temp Sensor, just replace them.
Posted on Nov 27, 2014
MY 2012 Ford Ranger 3.2 4x4 diff lock is not disengaging, although the diff lock selection is off in the cabin. What can be wrong?
This was built after I retired, so I will give you a little background. There were electric actuators and vacuum actuators. Some used pressure to move the actuators both ways and others expected the actuator to retract on its own. Corrosion or dirt could bind the actuator plunger. On the electric type the connector plugs could corrode. The vacuum models could have a leak or simply be too weak to return a stuck plunger. Try checking the electric plug or vacuum test any vacuum fittings on the unit.
May 01, 2017 | Ford Cars & Trucks
The key won't turn when I put it in.
You grabbed someone elses bike. If it has steering lock and the front fork is forcing it to move from lock, it puts too much stress on the plunger to turn the key. Try turnong toe handle bars all the way left or right when turning the key. Also you need to keep oil on the steering lock plunger so it doesn't corrode and jam.
Jun 14, 2015 | 2007 Honda Shadow Spirit
2007 dodge magnum idles too high and shuts off
Check connection to the idle air control on your throttle body. The iac has a plunger that moves in & out causing idle change. If the throttle body is dirty it restricts the iac plunger travel. Tru seafoam in your gas to clean fuel injection system. Follow directions on cam! Run the complete tank to clean system. Note: you will need to change fuel filter when done.
Reset computer by disconnecting - battery terminal for 20 mins or more.
Aug 07, 2014 | 2007 Dodge Magnum SE
My indesit dg1600 keep on draning all the time and does not start wash cycle
Check that the leveling switch isn`t stuck in the machine. lift the plunger out and clean slugged around the tube. make sure the plunger moves freely up and down
May 10, 2013 | Dishwashers
Bissell 1970 quicksteamer water runs out of clean water tank
Try re-installing the handle. Remove the screw on the back of the machine and pull up on the handle. Once the handle is removed pull the trigger to make sure the plugger on the end of the handle moves up and down when the trigger is pulled. If the plunger is moving reinstall handle and test. If the plunger is not moving you may need a new handle.
Sep 01, 2010 | Bissell 1770 Quicksteamer II Upright...
How to install a new fuel pump on a 1985 Chevy,305 V8,
Remove the plunger rod by removing the plate that is bolted to the block. Clean all parts if needed.
Apply some axle grease to the plunger rod and reinstall into the block, replace plate, then carefully install fuel pump, making sure the plunger is under the push rod.
Just did this same thing on my '66 283.
Dec 17, 2009 | 1985 Chevrolet Caprice
My '99 Pontiac Montana right sliding door and front door do not open. The windows and clock/sometimes CD player don't work nor does the A/C. Is there a fix? The fuses?
2 common possibilities. The plungers and plunger pads on the door and the door jam are corroded. Clean those off with a fine sandpaper, then put a dab of silicone grease on them. Then do the re-set procedure exactly as the steps indicate. If that does not help, then a possible door position sensor or the door control module is bad. A diagnostic using the on/off switch and the open/close switchon the system may indicate a code for door position problem. The door position sensor is part of the door motor/actuator assembly. The control module can be replaced separately. Info from here.
Nov 11, 2009 | 2000 Pontiac Montana
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Jun 22, 2008 | Timex Expedition 40141 Wristwatch
Pentair Master Temp 400K BTU Natural Gas Heater Low Nox ASME 460775 Logo
53 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
