What to do while formating c drive if automatically stoped copying files
  • 5,631 Answers
Restart format. If still stops, your drive is bad and you shoulld try to repair it doing a low level format with
HDD Low Level Format Tool v4.40
If after low leve format you still have problems while partitioning and formating, your HD has no repair
Posted on Nov 20, 2014
I can't drag and drop files on my Matsunichi 1TB USB 3.0 2.5" Portable External Hard Drive DM256
If you're on a Mac, it's possible the drive is formatted to NTFS, and in this case, would be stuck with read-only access.
If the drive is empty, you can format it to an Apple file system in Disk Utility.
If you are in Windows, it may be a similar problem. If the drive is empty, right click on it, select Format, and after running that process, you should be able to copy files to the drive.
If you have files on the drive, copy them elsewhere, format the drive, and copy them back.
Hope that helps.
Sep 19, 2014 | Computers & Internet
Tip
Recover deleted files
This is a tip explaining step by step how to recover deleted data, even if it is already deleted from your recycle bin. Before we start, you need to download the software required to complete this task.
Click HERE to download.
After you have downloaded the software, Disc Digger, all you need to do is to double click on .exe file to run the software. The program will automatically start. Now, for this purpose, I will recover DATA from my Flash drive. Click HERE to read step by step instructions a using a Flash drive.
I will copy some files to my flash drive, format the drive, then recover the Data I formatted. You need to remember that there will be more data recovered than the data I copied, because I have used this flash drive for a while, hence, the other deleted data will also be recovered.
So lets Start!!
For this purpose, I will copy a movie to my Flash drive, format my Flash drive and recover the movie.
Here is what I did:
After I copied the movie and the format was done, I opened Disc Digger, chose the drive on which I want to recover from, and started the recovery. The pictures below will explain the steps I Followed.
To open the application, just click on the extracted icon.
Now, i chose my Flash drive as the drive which i want to recover from, and clicked next to proceed.
I chose the dig deeper option, as this option will recover formated files as well, not just deleted files.
At this point you need to choose what type of file you would want to recover, i chose all file types.
Recovery process in progress. My flash drive is 8 GB in size, the recovery took 5 minutes.
Once the recovery is done, you will receive a pop up, which will state that the recovery is done.
Remember, that once the scan is complete, you need to save the files you have recovered. You need to create a folder in which you want to save the file, I just created a Folder on my desktop. Unfortunately, the name does not recover with the file, so you will need to look through the files recovered and after you have saved the recovered file, you need t rename it.
This software can also be used to recover photos from your SD memory card. Al you need to have is a SD card reader, which plugs into your USB port.
I really hope that you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
on Feb 28, 2010 | Baby Gear
Help, really don't know what I am doing, I am trying to sort out my daughters Acer laptop for uni. I tried to copy and paste windows from C drive to D drive, It would not complete the action, so now trying...
you just can not shift windows like copy and past from drive c to drive d. if you try to delete system files of windows it prevent action what may create damage to run windows properly. Keep your windows in drive c and if you want to remove copied files of windows from d, just format it. before format copy other files without windows as everything will erase on drive d. to format just right click of drive d> select format from menu. then copy back necessary files. Note: windows is system software called operating system, you can not setup or use to copy like other files and folders. Number of system files are hidden there.
Aug 23, 2013 | Acer Aspire 9410-4317 Notebook
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
Sep 04, 2012 | HP Computers & Internet
Why i cant copy files to hdd external (pqi h567v)?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or
you might tick one box then return after its finished the first repair then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Aug 29, 2012 | PQI 2.5" Portable External 750g Hard Drive...
Whenever i copy a files from external device lik cd dvd or usb. It automatically turns in encrypted format ie all files r in green colour. Can any1 solve this prob. Pls
You can go to the desktop folder and see if that whole folder is set as encrypted. Right click on the folder and clock properties. Then click the advanced button, and see if the encrypted check box is marked. If it is, see if you can clear the check mark.Try doing the same thing with any individual file that is encrypted. You can format a USB drive with some format other than NTFS. When you copy an encrypted file over to that USB drive, it should force it to be unencrypted, if it is being encrypted by EFS. Otherwise, it was encrypted before it was put on the CD or DVD, and there is nothing you can do except try to get the password used to encrypt it.
Jan 23, 2012 | Microsoft Windows XP
I am using a 8Gb usb flash drive. I formatted the drive. Copied the new bin files to it. The is no directory on the drive. I click the usb and it tells me there is no usb drive. I place the usb drive in...
You formatted the drive first - what format did you use? The HTS3520 can only read FAT or DOS formats (FAT-32 is the newest format that the unit can read.) (Most USB flash drives come with a FAT32 format.)
Alternatively, you could burn the upgrade files to a CD-R.
See http://www.p4c.philips.com/cgi-bin/dcbint/cpcontent.pl?mid=Link_Software&scy=BR&session=20110704115315_216.183.195.180&ctn=HTS3520/55&slg=ENG&dct=FUS&did=ENG&reldct=FUR&file=/files/h/hts3520_55/hts3520_55_fur_eng.pdf#toolbar=0&zoom=100 for the detailed settings for burning the files to a CD.
Jul 04, 2011 | Philips HTS3500S System
EVERY THING WHICH I COPY TO MY 32 GB PEN DRIVE WAS NOT WORKING PROPERLY IT WAS CORRUPTED AUTOMATICALLY
you would simply have to format the pen drive, although this will erase all informationon the drive, it will allow you to copy files to it in the future, to format the drive, simple go to
My Computer>Right click the pen drive>select Format>select which Format you want>Format the pen drive.
Jul 01, 2011 | Computers & Internet
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
Doesn;t taking large files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 19, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
