Question about Gaggia Accademia Espresso Machine
I have Accademia that is having problems with the initial rinse a warning triangle comes up with "water circuit primer" then it take 3-5 minutes to rinse and then fills the inside tray
2 Suggested Answers
  • 1089 Answers
SOURCE: Gaggia accademia displays empty grounds
HI
This is probably your solution.
http://www.fixya.com/support/t9715819-39_dregdrawer_full_39_message_but
Posted on Jul 23, 2011
The rinse aid error warning comes on and cycle stops. Filling rinse aid dispenser does not fix problem. What is wrong?
I appreciate your post, jake!
Based off the information you have provided it sounds like a potential problem with your rinse aid dispenser or control panel within your Frigidaire dishwasher. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to have issues with the dispenser I would recommend contacting a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Dec 03, 2014 | Frigidaire Dishwashers
'Water circuit priming'
and your solution to this problem was????
Mar 15, 2014 | Gaggia Accademia Espresso Machine
Tyre Pressure and ABS
By operating the tire pressure warning system reset switch, tire pressure warning system ECU can be set to issue a warning at an inflation pressure that corresponds with the type of tires.
Operate the tire pressure warning system reset switch only after the inflation pressures of all 4 tires have been adjusted on the vehicle.
To initialize the system, press and hold the tire pressure warning system reset switch for 3 seconds or longer with the power switch turned IG-ON. When starting the initialization, the tire pressure warning light blinks 3 times at 0.5 Hz.
During the initialization, the tire pressure warning system valve & transmitter measures the inflation
pressure of the tires, and registers the signals that are transmitted into the ECU at a frequency of 1 per
minute. The initialization process is completed when the signals from the tires have been received.
Once the tire pressure warning system reset switch has been pressed, do not turn the Ignition switch OFF for a few minutes.
Mar 05, 2014 | 2002 Toyota Corolla
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have an Audi A6 2.4lt Auto year 2000 my question is on the dash instruments there is a yellow triangle IE warning me something is wrong. My gear selector jamsgets stuck will not move, I had water in...
Have someone check and see if the brake lights come on when you press the brake pedal..The warning lamp may indicate a fuse out to the brake light circuit--if the fuse is blown/faulty then the gearshift won't move, it needs to "see" the brake circuit is on before allowing the shifter to engage.
Aug 16, 2009 | 2000 Audi A6
Have similar problem. Not heating up and no hot water available.
If there is no heat at all and these lights are showing, this could well be that the generator has blown (sometimes this will cause your home's circuit breaker/fuse to trip at the same time). It will probably need professional help! To repair this at an authorised service centre (June 2009) cost me $170 AUD for a replacement generator + labour (translates to about $135 USD).
Jun 06, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Frigidaire front loader - clothes come out very dry
be sure and ckd fill hoses the screen on cold hose may be plugged the first bit of water is usually hot or warm to flush detergent the remainder is warm or cold also cold is normally used on all rinse
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Gaggia Accademia Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
