Hp computer, keyboard& mousee need to reconnect Computer said keyboard error
    Problem Solver:
  • 7 Answers
Is this an HP Wireless Keyboard & Mouse? If so, I would recommend uninstalling the driver and installing the most up-to-date driver for your version of keyboard and mouse. You could also try connecting the wireless dongle to another USB port on your computer, but if you are receiving an error, the problem is driver related.
Posted on Nov 26, 2014
My HP keyboard sometimes doesn't work. I can turn my computer off and back on again and it works. Can you help me solve this problem?
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
Apr 25, 2011 | HP Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
When i press number lock, a light does not come on. when i press cap locks the light wont come on
Restart your computer without the keyboard, It will give you an error, Then turn off the computer and reconnect the keyboard and start it again. Should clear anything bad up, if its still not working then may be time for a keyboard
Sep 10, 2010 | Computers & Internet
The keyboard completely stopped working. Unable to type at all...any suggestions? I have disconnected and reconnected the keyboard and restarted the computer.
Turn off the computer, disconnect and reconnect the keyboard, restart your computer. If that does not work, try a different keyboard. If that still does not work than try a usb keyboard instead of a ps/2 keyboard or vice-vers. Good luck and let me know how it goes.
Aug 29, 2010 | Compaq Keyboard
Wireless mouse wrks wireless keyboard does not! Do I need a separate wireless dongle for each?
If you have a matched board and mouse you only need one and you have to press the button on the keboard then see if it types then do the same for the mousee push the mouse button down and it should connect. However this is for a matched set keyboard and mouse.
Jul 10, 2010 | HP Pavilion dv6000z Notebook
My hp wireless keyboard and mouse doesnt work
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 19, 2010 | HP USB Wireless Keyboard/Optical Mouse...
Keyboard is not working
  • Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the Computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 31, 2010 | HP Pavilion dv2000 Keyboard
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Computers & Internet Logo
David Payne
David Payne
