Question about Welding Tools
Welder turns on but won't ark - Welding Tools
  • 1,384 Answers
If won't arc, then the feed is not moving the wire because the trigger button is not making a connection. Bad trigger. If the wire does feed, then your cable connection is responsible and needs cleaned and tightened.
Posted on Nov 15, 2014
5 Suggested Answers
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
  • 81 Answers
SOURCE: will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
Posted on May 05, 2010
luis_david
  • 407 Answers
SOURCE: Have a ground and wire is running but will ark intermited
There are two items I would like you to do:
1) Change your contact tip and try again. Make sure the wire is running smooth thru the gun. If this not cure the problem then go to step two.2) Change your wire. If it is too old probably is rusted and not making proper contact.Hope this help.
Posted on Nov 30, 2011
My mastercraft ark welder turns on but won't ark the overload switch is not on
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
Nov 15, 2014 | Garden
Nov 30, 2011 | Welding Tools
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Will feed wire but will not start an ark to weld
May 04, 2010 | Hobart 500526 Handler 210 Professional...
Millermatic251. After turn on, the gas pulses or puffs at about 1 sec intervals, with the trigger off. When I weld the gas works ok. Any ideas?
Sounds like a shortcircut ( probably a burnt wire) on your gas solenoid intermittently arking to the body of the welder if you are using a two stage handpiece it could be the trigger.
Mar 28, 2010 | Welding Tools
Ark blow and like a loud ark only sometimes on 305
need to change your polarity or change location of your ground on the peice you are working on if running left to right put ground on right
Dec 14, 2009 | Lincoln Electric Ranger 305D K1727-2...
Welder feeding or arking
Jan 18, 2009 | Welding Tools
Manual for a Cambell Husfeld welder Model WF2000
You can download PDF versions of the manuals for CH welders at the Campbell Hausfeld website.
Look on the left under the Service Center heading for a link to manuals.
Rank this answer if you found it useful,
Carl
Sep 20, 2008 | Welding Tools
Welding Tools Logo
76 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
