My bush lcd won't turn on the white standby light is on but it just flashes and nothing happens when I try to switch it on can anyone help
Won't switch on
  • 2,210 Answers
Its had the circuit board or tube fail. Probably not worth taking to an agent. Get online or local small adds and find another tv.
Posted on Nov 15, 2014
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
stonephoenix
  • 563 Answers
SOURCE: my t.v won;t turn on just is in standby was
There is a part inside the TV that needs to be replaced. If the TV is under warranty, call the manufacturer and they will arrange to have your set repaired at little, or no cost to you.
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the unit yourself. Otherwise, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you take the TV to a repair shop for out of warranty repair, the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Since some brands will pay for your repair even if you're out of warranty, you should contact the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Sep 06, 2009
djromann
  • 158 Answers
SOURCE: When I turn tv on
Check the power supply mainboard if there are inflated electrolytic capacitors, to replace them.
Posted on May 16, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: TV won't turn on with
The flashing timer light blinks out a code, where it flashes some number of times, pauses, then repeats. The code indicates what fault is keeping the set from coming on. Unfortunately, all the codes tend to mean that there is some electronic problem with the TV. Unless you have some electronic servicing skills and the necessary equipment to troubleshoot the problem, you'll need to have set checked by a professional. For any code there can be many causes, so I can't offer any other advice.
This might be a good time to check sale prices on LCD sets. Let a technician check the set and give an estimate for the repair, then decide.
Posted on Jun 08, 2011
caroldon
  • 17130 Answers
SOURCE: won't turn on, standby light flashes then
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section. Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multi-meter to check the continuity or shorting in components, if so detach from circuit and test. If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly, the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on Oct 15, 2011
I HAVE A BUSH LED22982DVDFHDS THAT WON'T TURN ON STAND BY LIGHT KEEPS FLASHING
Flashing of standby light are fault indications, technically called blinking codes. From the number of flashes that occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Blinking codes to many brand TVs are described in detail.
Apr 21, 2013 | Bush Televison & Video
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
Bush 32ODTR DIGITAL TV RECORDER WON'T SWITCH ON BUT STANDY BY LIGHT IS ON
there might be a slight loose connection have a look and make sure all cabels are plugged in .
Jun 06, 2012 | Bush Televison & Video
Bush B32ODTR WON'T SWITCH ON
There is missing secondary power supply rail/s from the main power regulator board to other boards of this TV. Seek tech support.
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Bush lcd 27006 standby flashing
Jan 06, 2008 | Bush 5693D 24" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
