Lg front load washer is over filling during pre wash
  • 2,210 Answers
Get someone to check the incoming water valve. Its not a big deal to change if faulty.
Posted on Nov 15, 2014
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
Washer_tech
  • 164 Answers
SOURCE: Front Load Washer
you have most likely a bra underwire stuck inbetween the tubs. usually it doesn't work itself all the way thru. with a flashlight, a pair of needle nose pliers and patience you should be able to find and extract it.
Posted on Jun 08, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
App King
  • 55 Answers
SOURCE: LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Posted on Jul 16, 2009
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Prewash hose comes loose
have you cleaned the pipes out there may be a blockage
do look at where the pipe pops off from??? and where it goes on ??that may want cleaning out????
Feb 03, 2014 | LG WM2455 Front Load Washer
My LG front load washer is leaking during the rinse cycle. I cleaned the filter and it is still leaking. What should I do?
Leakage can be a few things..Check the door boot seal for any small rips, next the fill hoses are the watertight, next drain hose , now under the machine is the pump ok, Last assuming all hoses are ok has the drum a hole in it...good luck
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Jan 02, 2010 | LG WM2455 Front Load Washer
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
