Where can I find the fill switch - Washing Machines
  • 2,210 Answers
Disconnect the machine from the power. Remove the top panel, usually there are a couple of screws on the back and the panel slides rearward to remove. The valve is about a 1/4 of the way down fixed to the frame and has a tube running down to the lower plumbing. If its not the incoming water valve playing up then get the level valve checked.
Posted on Nov 15, 2014
Wont stop filling
The fill solenoid is stuck in the open position. Replace it for proper operation. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Amana Washing Machines
Washer not filling with water
sounds like a defective pressure switch that is just a spdt pressure operated switch and its stuck on the timer side of this switch and can't switch back to the fill side of the switch to fill the machine first before starting agitation,check voltage from the water fill wire off this switch for line voltage,then check from the wire on this switch to the timer for line voltage,probably no voltage from the water fill valve wire so it can't fill
Feb 21, 2013 | Kenmore Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Indesit dishwasher overfilling
There are two ways that dishwashers generally fill. One is a float inside the tub, the second is a tube which fills with water, loops and goes to a pressure switch below the machine. That switch is usually about 1.5 inches in diameter, two wires and a small hose going to it. The float witch is found below the float in the motor area. With the float, sometimes they jam with too much old detergent or food goo. Clean out. Both can have the switch weld closed. Change the switch in either case. Since the unit is not filling with the power off, I'm going to guess the water solenoid is okay.
Dec 22, 2007 | Dishwashers
Kenmore Series 80 won't stop filling.
Kenmore washers
Fill switch
pull off fill knob
remove plastic trims from front face ends of control panel exposing screws
remove phillips head screws from bottom
slide control panel forward & up ~1inch then flip over backwards on top hinges
to remove fill switch
depress lock tab right side where switch body touches back of control plate
rotate counter clockwishe 45-90 deg
withdraw fill switch
remove plastic tube from switch body
Blow any water out, should be empty when washer is empty messes up pressure sensing
refit plastic tube
adjustment screw is 1/8" hex head bolt next to knob shaft
clockwise raise water level
counter clockwise lower water level
can be operated in this open position to check operation, may have to move switch between fill positions to restart fill operation
Nov 27, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
