Workhorse 210000 btu will not run with cover on what is the problem
Replaced all rubber lines cleaned photo cell cleaned fan and all parts related will not run with cover on shuts off within a minute what could be the problem
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
Try cleaning it out. These also have a thermostat for auto on/off, make sure it is set for the right temperature setting.
Good luck
Posted on Nov 15, 2014
humanman42
  • 82 Answers
SOURCE: Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Posted on Dec 03, 2008
SOURCE: 150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
the heater runs good but don,t seem to run clean.
will start to make eyes water
Posted on Dec 27, 2008
tbirdfan1
  • 3051 Answers
SOURCE: need fan and motor for blower on dyna glow 210000
Hello there:
If you remove the old motor and fan and just take it to either kragen or autozone they will have the fan and motor for you it will cost about 45 dollars fro this ok
Hope this is helpful for you
Best regards MIchael
Posted on Dec 22, 2009
  • 224 Answers
SOURCE: I have a 55,000 BTU
Water in the fuel tank, I personally had this problem this morning irritating but was simple to cure. Empty your fuel in to a clean five gallon bucket and observe, fuel is lighter than water and will float on top water settles to the bottom. You now have to dry out the tank, get creative I stuffed mine with rags and sopped it all up, this worked fine for me. You can siphon off the fuel from the water and re-use the fuel. Just be careful not to siphon off the water with it.
Posted on Dec 23, 2010
  • 67 Answers
SOURCE: I HAVE A WORKHORSE 65,000
Ken's Repair Ph 7403694798 or e-mail Kcox7@columbus.rr.com
Posted on Jan 19, 2011
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a 55,000 BTU Reddy Heater that runs on K-1 Kerosene. I used it several weeks ago and it seemed to stik far more than usual. I tried to used it yesterday and now it seems to come on for a second...
Dec 23, 2010 | Reddy Heating & Cooling
I have a Goodman 3 ton 70,000 BTU gas furnace that has started making a rattling noise from a small fan with a 1/4 " rubber hose leading away from it. I was told that it has something to do with...
its the fan which takes the fumes up the flue its the combustion fan the hose goes to the pressure switch you will need make ,model, serial number of heater btu input , you can replace this your self just swop like for like , try looking on line for a price .
Dec 06, 2010 | Goodman GMS90703BXA Heater
Need fan and motor for blower on dyna glow 210000 btu kerosene heater
Hello there:
Dec 22, 2009 | Cfm Heating & Cooling
Printer prints every second line or prints 4 lines then skips a line or only prints half a line.....the top part of the line is missing.
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Sep 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Feb 19, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Feb 03, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
35000 reddy kerosene heater
My unit is a kerosene 35000 btu unit...just had similar issue.
It is very possible that the spark plug is
  1. fouled out (dirty)
  2. mis-gapped
take the top cover off, you will see the plug. There is a sheetmetal plate held on by two screws holding the ground, plug, and nozzle together. It is easier to just remove the plate (you will have problems with the plug nut if you don't).
remove the plug with a plug socket, probably 5/8.
I used brake parts cleaner to spray off the electrode of the plug then a wire brush to clean it.
check your plug gap...this might be crucial. my gap was specified on a label stuck on the inside of the bottom of the body. The plug on my unit was way too small. Adjust gap if necessary using feeler guages.
reinstall parts and plate. (I actually tack-welded the plug nut into place for ease of maintenance later). Note that the electrode needs to be a specific angle, relative to nozzle....probably diagrammed on the same label as the gap spec.
replace top and see if she'll fire up.
...last note...also might check your fuel pickup/filter. It is located behind the side panel in the unit
good luck...hope I have helped you
Dec 28, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
