I bought a encore 2 forgot my password so now can't get into it. Is there a factory reset for these if so what is it
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
Try pressing the power and on screen button at the same time for no more than 30 seconds. If this doesn't work, you may need to go into your settings and go from there.
Posted on Nov 15, 2014
  • 63 Answers
Forgot password
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Nov 14, 2013 | RCA Tablets & eReaders
Forgot password username
I believe this model has a reset button in the back. Hold it in with a pin till it cycles through. This will clear all custom settings and reset to factory.
May 28, 2013 | Encore ENHWIN3 Wireless Router
Forgot my password and cannot reset?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 06, 2011 | Computers & Internet
I forgot the password and i want one new please. my router model is ENHWI-SG im in argentina
On the Router there is a RESET button. Press and hold it for 10 seconds. then plug into the router and run the set-up wizard.
Mar 02, 2011 | Encore WL ROUTER |ENHWI-SG 54M 11B/G...
Forgot my password how can retrieve password so i can unlock it
you can use the reset button in ur router to get back it to factory settings.
Remove all the cables from router and press & hold reset button for 15 secs.
This will reset your router after whicg you can create a new password.
Nov 15, 2010 | Encore Wireless Router
How can i reset my password???
Use a pin-shape item to push to reset this device to factory default settings. It will be useful too when the manager forgot the password to log in, but the setting will be back to default setting. this found next to the power connector (right ).
Aug 10, 2010 | Encore Wireless Router
How to reset the admin password on the router
On the back panel of the router there should be a small hole into which you can press the point af a Biro. This resets the router to factory defaults which should be...
user name : "admin"
password: "password"
Apr 18, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I forgot my password for my router how do i make a new one?
There should be a Reset Switch a real small hole in side of unit, push a straightened paper clip in, and push gently, and it will "Reset" unit back to factory settings ...Whereby ya can set it up again.
Jan 24, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I forgot my password for my encore router
If you are referring to the password to get in to the router page, it is admin for both username and password field.
Dec 23, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
