Question about Sparco high volume electric three-hole punch, 3 punch heads - 30
How can I buy a replacement cord for a sparco 96003 3 hole punch
Just need a cord!
    Sergeant:
  • 266 Answers
I wouldn't mess with a cord, you need to get a new machine.
Posted on Nov 25, 2014
Looking for a replacement cord for a sparco 96003 hole punch
Use any cord from something your throwing away that has a ground in the wire making it a 3 wire cord. White is common, black is power, and green is ground.
Nov 15, 2014 | Sparco High Volume Electric Three-Hole...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Can you buy hole punches that are shaped?
Yes you can buy hole punches that have different shapes. it's great for scrapbooking, card making or just decorating a page.
amazon have a few that are very reasonably priced, like this star fish one for $4;
http://www.amazon.com/Starfish-Shaped-Punch-Crafting-Scrap/dp/B005JFHGYO
Jan 14, 2013 | Office Equipment & Supplies
Replacing starter pull cord on 77 20hp mercury
Remove the starter housing from the top of the motor and see if the spring broke or back wound it's self when the rope broke. If all is well remove the rest of the rope from the spool by feeding it back thru the guide hole the handle rests on. Wind it out and find a hole drilled thru the spool and put a punch thru it to lock the spool in place against the spring pressure. Remove the old cord. If it has a steel hook glued to the anchor end you will need a real mercury part. If it has a knot. your in luck.
Take your new cord and burn one end and roll the cord to a point while it is still molten. Tie your knot and heat it till it is cooked so it won't untie itself. Feed the pointy end thru the spool and out the front of the housing. Tie a knot it it where the handle would go. Gently feed the rope on to the spool when you remove the punch.
You will have more rope than the spring could wind. so untie the end knot and feed it back to the spool and put the cord in the notch of the spool so it won't rub on the housing and wind a few more turns into the spring .
When it has enough pressure to completely wind the cord up. put the punch back in the lock hole and feed the cord out the hole thru the handle and knot it, then cook that knot as well.
Sep 16, 2012 | Boating
How do i remove harmonic balancer & replace
YOU NEED A HARMONIC BALANCER PULLER TOOL AND A 15M SIX POINT SOCKET TO REMOVE HARMONIC BALANCER BOLT.TURN OFF RADIO AND REMOVE THE DRIVE BELT AND REMOVE THE NEGATIVE BATTERY CABLE. REMOVE THE STARTER SO YOU CAN PUT A LARGE SCREW DRIVER OR LARGE PUNCH TO STICK IN ONE OF THE FLY WHEEL HOLES TO KEEP ENGINE FROM TURNING WHEN YOU LOOSEN THE HARMONIC BALANCE BOLT. ALSO SCREW DRIVER AND PUNCH CAN KEEP ENGINE FROM TURNING WHEN REMOVER THE HARMONIC BALANCER. YOU WILL NEED A HELPER TO HOLD PUNCH OR SCREW DRIVER WHILE YOU LOOSEN THE BOLT. YOU CAN GO TO SEARS OR ANY AUTO PARTS STORE AND BUY HARMONIC BALANCER PULLER.TORQUE HARMONIC BALANCER BOLT TO 76 FT LBS.
Apr 23, 2011 | 2003 Pontiac Montana
I need to put an extra hole in my watch band because it does not fit.What way can I do this at home,if any
The best way would be to buy an inexpensive leather 'punch' at an arts and crafts store. They aren't expensive (Asian stuff) and have 5-6 punches of different sizes on a rotating drum and produce a clean hole. I've found other uses for them as well.
Oct 07, 2009 | Watches
Sparco high volume electric three-hole punch, 3 punch heads - 30 Logo
69 people viewed this question
Top Sparco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sparco Office Equipment and Supply Expert? Answer questions, earn points and help others
