Question about Maytag Refrigerators
I have a maytag side by side MSD2576VEM00 when the door is closed on the freezer the auger motor keeps running when you open the door it will go off if I have the door open and push the light (door) b
Maytag side by side MSD2576VEM00 ice maker motor (auger) keeps running until I open door I tried to unplug and plug back in same thing the auger start spinning and don't stop till you open the door
  • 1,564 Answers
Take a look at your ice maker. Look for ice that is causing the auger motor to run. Clear the ice and try again.
Posted on Nov 15, 2014
Testimonial: "iremoved the whole ice tray the ice motor keeps running when you open the door it stops soon as you close the door it starts running again"
  • sylviaivie Nov 15, 2014
    Ok, I was hoping it would be that easy. The next thing is to get out your books that came with the machine. (sometimes they tape them to the back of the fridge) Look in the troubleshooting section for this problem. Hopefully it won't be something too hard to fix.
SOURCE: MFI2568AEQ
i fixed the problem with my fridge i hope it will work with everyone best of all at no cost unplug the fridge and plug it back in do this four times back to back leave it pluged in on the fourth time and then hold the light and lock button for three seconds it seems to reset and work fine i hope this is a cure and would really like to know if this helps vulcanv88@aol.com
Posted on Aug 01, 2007
SOURCE: Ice Maker door flapping-Contral panel flashing
the solution is to replace the High Voltage Board. It's 149.99 usually. part number is 12920710. Call me if you want one. My cell number is 516-650-6167.
Posted on Aug 04, 2007
aborcass
  • 2651 Answers
SOURCE: Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Posted on Feb 23, 2008
  • 106 Answers
SOURCE: Whirlpool GS6NBEXRS01 ice auger motor
Un plug refrig. Check continuty on auger motor(ohms). If open winding or no continnuty motor is NG. Or rig a power (cheetercord)cord to apply 120v to motor to see if it will run. If the frezer door is open the door switch kills power to auger motor. Check door switch. If power is fed by a circuit board in the door pannel it my be NG. Or just the micro switch that the paddel hits when you push a glass up to it is NG or not being hit.
Posted on Oct 31, 2009
  • 532 Answers
SOURCE: Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Posted on Jul 12, 2010
My Ice dispenser is not dispensing.
Hello;
My name is peter. I am a retired field service refrigeration technician.
You did not provide a model number so I am not sure of your wiring schematic.
You my have a double inter lock on the light switch on the left hand side of your freezer. It is a safety device.
Pop it out with a flat head screw driver. If you have 3 connectors then you have a double interlock switch. This is a safety device to prevent the auger from running if the door is open. If the switch is bad then the auger will not run regardless if the door is open or closed. Jump the switch with the door open the auger if bad will run. Replace the switch.
Feb 27, 2016 | Refrigerators
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Ice dispenser doesnt work
Have you tried taking your ice bin out and checking for melted ice that can freeze locking the auger and preventing its movement? Another item to check is wiring going to and from the dispenser. Many times corrosion sets in the pin plug just behind kick plate. If the auger motor is not turning at all then I would believe that you may have a defective door light switch that also controls a lockout when door is opened. That light switch tells when door is opened while the opposite happens when door is closed. If that fails then we need to see how much voltage is present at the auger motor leads just behind the rear panel of your freezers auger motor assembly. To test the auger motor leads you need to have someone hold door light switch in and press dispense ice while someone checks motor leads with a voltage tester. If you have questions I will be glad to answer them for you, Thanks, Sea Breeze
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our power went out a week ago and since then our Kitchenaid side by side will not despense ice from the door,it makes ice but will not dispense. We cleaned it our thinking ice had melted and then refroze...
The auger motor is frozen. Open the freezer door and remove the 4 screw holding the auger motor. Unplug the harness. Put it on the counter and use a blow dryer to defrost it. Shake out the water thats inside. Do this until u think all the water is out, then put it back in door and plug it in. You should be good from then on. If you loose power again. Remember to remove ice bucket or water will leak into motor again.
Jul 17, 2011 | Refrigerators
Broken ice dispenser
try and remove the ice bin.the watch the auger motor while the door is open and the switch help close while some one is tryind to dispence ice.if the auger turns the check and see if the u shaped braket is stripped you can tell this by grabbing it and turning back and forth it should only move one way.if it does not turn then the auger motor does need to be replace.make sure to check the wiring as well.if the motor turn check th is bin and make sure there is no ice jammed in the teeth of the auger this wolud stopp it from turning.i hope this was some help to you good luck. would like to here how things go for you.
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
528 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
