Question about Sparco High Volume Electric Three-Hole Punch 96003 SPR96003
Looking for a replacement cord for a sparco 96003 hole punch
Need a replacement cord?
  • 1,522 Answers
Use any cord from something your throwing away that has a ground in the wire making it a 3 wire cord. White is common, black is power, and green is ground.
Posted on Nov 15, 2014
I have a ryobi weed eater expand it that will run but won't cut. Any drag stops it. I tried to tighten the bolt on the head and realized it just spun the whole head. I can't loosen it either. Do I need to...
drive shaft not installed right take it back apart reline cable into connections to check when you pull starter cord head should rotate has far as the head tighten there's a cap washer looking piece on bottom of shaft. spin that around tell you find a hole on the side put a drill bit or small punch in hole this will lock the shaft up so you can tighten or loosen the head or blade
Sep 06, 2014 | Garden
HOW TO PUNCH HOLES
If your copier has a hole punch unit you should be able to go to output and select hole punch.
If you're trying to print with hole punch from your computer and you dont have the option, you need to configure your print driver. Check out the link below for instructions.
How To Configure Sharp Print Drivers with Installed Options to print...
www.equipmybiz.com
Aug 05, 2014 | Sharp MX-3501N All-In-One Printer
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Replacing starter pull cord on 77 20hp mercury
Remove the starter housing from the top of the motor and see if the spring broke or back wound it's self when the rope broke. If all is well remove the rest of the rope from the spool by feeding it back thru the guide hole the handle rests on. Wind it out and find a hole drilled thru the spool and put a punch thru it to lock the spool in place against the spring pressure. Remove the old cord. If it has a steel hook glued to the anchor end you will need a real mercury part. If it has a knot. your in luck.
Take your new cord and burn one end and roll the cord to a point while it is still molten. Tie your knot and heat it till it is cooked so it won't untie itself. Feed the pointy end thru the spool and out the front of the housing. Tie a knot it it where the handle would go. Gently feed the rope on to the spool when you remove the punch.
You will have more rope than the spring could wind. so untie the end knot and feed it back to the spool and put the cord in the notch of the spool so it won't rub on the housing and wind a few more turns into the spring .
When it has enough pressure to completely wind the cord up. put the punch back in the lock hole and feed the cord out the hole thru the handle and knot it, then cook that knot as well.
Sep 16, 2012 | Boating
Sparco High Volume Electric Three-Hole Punch 96003 SPR96003 Logo
102 people viewed this question
Top Sparco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Sparco Office Equipment and Supply Expert? Answer questions, earn points and help others
