Question about Ovens
I have oven siemens HB 73AB.50, i put on auto cleaning , but now it shows e106 and the door wont unlock
It never started the cleaning, after 1-2 minutes this e106 showed
reg501
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
  • 163 Answers
SOURCE: oven door will not open
Resetting this switch solved my problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should fee a click.
Posted on Jan 02, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
SOURCE: oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Posted on Apr 16, 2010
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
How do I start self cleaning oven hb 760.60
usually by locking the door shut with the lever or the auto control .
Feb 22, 2015 | Ovens
I have siemens oven, i put on self cleaning put now i have e106 and it is locked
Unplug the oven (or turn off the breaker) for 60 seconds, now turn it back on. If the error persists it will require a technician to repair the latch and reset the error.
Nov 15, 2014 | Ovens
How do I end auto clean
try to unplug it from receptacle for 1 hr the reconnect to reset chip
Sep 16, 2014 | Ovens
HBL3350UC wont unlock and throws error E106
Link to user manual download (right column UI equals user information,) However it only says that if you get an error code to call for service. Sorry I couldn't be of more help
. Order Management System
Aug 16, 2014 | Ovens
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
How to fix e106 error Bosch oven
Does anyone have step by step instructions on how to clear E106 code on a Bosch self clean oven please.
Thanks Yvonne
Mar 21, 2012 | Ovens
I have error code E106 on my self cleaning Bosch oven
I had same issue - A simple switch off/on at the main breaker for the oven was enough to resolve it.
Mar 01, 2012 | Ovens
I can't get my Siemens oven self cleaning feature to work. I first set the dial to the cleaning position. I then try and set the temperature dial. As soon as I turn the dial the beeper sounds with the...
You have to take everything out your oven all the removables , then turn knob to pyrolyse and the other knob to 1 for mild cleaning 2 for medium and 3 for heavy cleaning
Jan 10, 2011 | Siemens Ovens
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
