Question about Ovens
I have siemens oven, i put on self cleaning put now i have e106 and it is locked
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
Unplug the oven (or turn off the breaker) for 60 seconds, now turn it back on. If the error persists it will require a technician to repair the latch and reset the error.
Posted on Nov 15, 2014
Testimonial: "Thank you , tried it but wont work"
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
  • 188 Answers
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Posted on Apr 03, 2009
  • 59 Answers
SOURCE: self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Posted on Apr 27, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
SOURCE: We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Posted on Feb 21, 2010
Testimonial: "Thanks"
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
How to fix e106 error Bosch oven
Does anyone have step by step instructions on how to clear E106 code on a Bosch self clean oven please.
Thanks Yvonne
Mar 21, 2012 | Ovens
I have error code E106 on my self cleaning Bosch oven
I had same issue - A simple switch off/on at the main breaker for the oven was enough to resolve it.
Mar 01, 2012 | Ovens
The door won't lock when I put it in the self cleaning mode.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 16, 2011 | Jenn-Air Ovens
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
good luck
Feb 01, 2010 | KitchenAid Ovens
Self cleaning oven won't start self clean mode
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven door locked will not open
try putting the stove in self clean when it goes in for about 1 minute cancel the self clean see if it opens.
Nov 30, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
324 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
