Question about Whirlpool Dishwashers
<!-- from fixya rte -->Where do the white balls go in my dishwasher - Whirlpool Dishwashers
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
They dissolvve and go down the drain.
Posted on Nov 15, 2014
It wont wash
Was the water turned off? Is the float ball missing from the center stem? This ball is commonly orange and sometimes white. Very little information couldn't possibly help me help you in this regard.
Sump pump chamber ball - Many times this ends up being wet vac'd out.
Nov 08, 2014 | Dishwashers
Whats the white ball in the drain line of my dishwasher for
The white ball is suppose to be in the float that's whats stops the water when it's at it's fill line please post pics of where it's at now so I can further assist u
Mar 02, 2014 | GE Dishwasher Ball Check - WD12X10246
After removing the bottom assembly and filter to clean them, I found a small white ball in the bottom of the dishwasher. Where does it belong? The wash blade doesn't spin.
You probably have the check ball that sits below the volute cover that fits in the center of the sump housing. This is part of the Motor & Pump assembly. For a picture of the unit, see http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5120395&diagram_id=381580#d381580 (the parts diagram) .
For the exact diagram, check which model FDB510LC dishwasher that you have: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FDB510LC .
I hope this helps.
Jul 30, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
My Whirlpool leaving white powder on dishes, film on glasses. Worse when rinse agent used. Water tests 120 degrees. What is best det. to use? Dotutah
the small electralsol cubes with the red ball,plus run your dishwasher with C.L.R. it will clean all the residue in your dishwasher
Mar 29, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Dishwasher just over a year old. Very slow to
The little white balls are check valves - you need them.
Have you checked the discharge check valve under the dishwasher where the discharge line connects to the sink? It is under the unit and can be unscrewed (carefully). The valve can be disassembled with a couple of pronged keepers. This check valve can become obstructed and cause the problem you decscribe.
Dec 12, 2009 | Estate TUD6710 Built-in Dishwasher
Dishwasher will not drain all the water out
If this is a GE or Hotpoint dishwasher the solution is fairly easy, but a pain. GE (Hotpoint is the same company) has been using a small plastic ball that prevents backflow of the water. A lot of times that ball migrates and doesn't allow the dishwasher to drain. To get to this, you need to remove the two 1/4 inch hex head screws in the food trap basket, the 1/4 inch hex head screw from the spray arm, and use a small screwdriver to pry a clip at the back of the spray arm up to remove the spray arm assembly. Siphon as much water from the dishwasher as possible because you'll be opening up the plumbing below. Turn off your electricity to the dishwasher and pull it out of the cavity. Directly behind the motor is a large manilla-colored "tank" with a large hoseclamp holding a white union with two smaller hoses coming off it. Loosen and remove the white union from the large tank and the ball should fall out. Replace the white union, tightening the hose clamp and drop the ball back into the tube on the left side of the food trap basket. Put it back together and test run.
Sep 10, 2009 | Dishwashers
Water will not drain. Motor is working. Drain does not appear to be clogged.
GE has equipped many of their dishwashers with a crappy anti-syphon ball. The problem with this is that they often relocate and clog the drain. To fix it, syphon all the water out of the basin of the diswasher and remove the kick plate. Open the dishwasher and remove the 1/4" hex head screw behind the food screen and remove the spray arm by prying the plastic clip on the back side (be careful not to break it). Then remove the two 1/4" hex head screws in the plastic basket and remove it. Remove the two screws that hold the dishwasher to the countertop and slide the dishwasher out. There is a large manilla colored hose with a huge hose clamp on it. Have plenty of rags on hand because this part gets messy. Remove the hose clamp and pull this area open. A small white plastic ball should roll out. Replace the hose clamp and slide the dishwasher back into place (clean up all the water that escaped first, and make sure you have turned off the power to the dishwasher before beginning). Drop the ball into the small tube on the left side under where the plastic basket goes. Installation is reverse of removal.
Aug 03, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool gold dishwasher
yes they are part of the assy. and need to be put back to function . whatever level of dissaslby you were at when you found them is where they belong. you can see by flipping over the last removed plate a little chanenl where it looks like the balls would go( the d/w fills with water and diff. pressures hold them against or push them down) depending on operation.they go in seperate openings as well
Mar 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
52 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
