Question about Health & Beauty
My scooter putts when throttle is fully opened and speed increases
  • 1,263 Answers
Hi , sorry what is putts, do you mean jerks ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Nov 17, 2014
How do I increase the speed of my pride mobility scooter
I believe you would have to change the throttle pot
Nov 20, 2016 | Pride Health & Beauty
Governor linkage
There are two main types of governor and the centrifugal type tends to be reserved for heavier stationary type engines. Most portable lightweight appliances use a vane-type governor where a vane is placed adjacent to the cooling fan so the faster the engine revs the more air is moved and the more the vane will move against it's restraining spring.
There is a spring biasing the throttle to fully open and this spring is connected to the throttle or speed control lever.
There is a link connecting the throttle to the vane. After starting the engine speed will rise until the governor vane moves under the rush of cooling air forcing the throttle butterfly to close against the spring pressure until the vane pressure and the spring pressure are equal and therefore a constant engine speed is achieved.
Moving the speed control lever to increase speed tensions the spring and opens the butterfly causing the engine speed to rise until the vane force again equals the spring pressure.
This is a fairly basic but very common type. There are variations using two or three springs but the principle remains the same.
Aug 10, 2016 | Garden
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
Why when mobility scooter not moving when engaged but when disengaged moving slightly
The unit is not made for "medical approved" market and does not have a POST (Power On Self Test) to confirm wig-wag (throttle) is in neutral when it first turns on. SOLUTION: Put the scooter up on blocks so the drive wheels are off the ground. With the SPEED KNOB turned fully clockwise, adjust the wig-wag (throttle) so the cart will not run and the brake is engaged when the cart is in neutral. There are usually Allen screws in the wig-wag handle that can be loosened and re-tightened once the wig-wag pot is properly centered for neutral.
Aug 09, 2014 | Electric Strider Maxi 4 Wheel Mobility...
After starting my 98 metro 1 liter the idle increases in less than a few minutes until the engine is racing so fast I have to shut it down, help?
Generally speaking, the only way for the idle speed to increase is if extra air is getting past the throttle plate.
So that could include the throttle plate sticking open, the idle air control valve not closing, or a vac leak somewhere such as a hose or gasket.
If you can cover the throttle body with something and the engine still runs at a high speed there is a large vac leak somewhere.
Jan 22, 2013 | Cars & Trucks
How do I increase the idea on a 98 HD heritage springer
If you're talking about the idle speed of the engine, there is a small stop screw on the right hand side of the carb. where the cables attach to a round metallic disc. This disc is part of the throttle shaft. The wider it opens, the faster the engine runs. The idle stop screw regulates the postion of the throttle shaft when the carb is fully closed by the cables. Adjusting the screw inwards increases the idle speed.
I hope this is the information you are looking for. If not, please repost. Good Luck!
Feb 11, 2010 | 2000 Harley Davidson FLSTS Heritage...
I have a pride scooter that will not run at top speed. When speed control is turned to fastest setting, the scooter goes dead.
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
Oct 30, 2009 | Pride Mobility Victory 3 Wheel Electric...
How do you slow the unit down?
use the speed pot on the from control panel, if it still too fast take off the control panel,
look for the three throttle wires, pick the left hand , now get a 5k pot from maplins or rs depending on your location, wire the central locator and the left or right side locator as a straight connection so one wire from the left let and one wire to the central leg now take a wire off the throttle and connect to one piece of wire and the other to the other end of the wire, hope that makes sense, now you increase the resistance from the pot and now when turn fully on for boths pots will slow down the scooter
Regads
GeWiz.
Sep 30, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
53 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
