Question about Kitchen Ranges
What causes and what can we do to fix this problem with our kitchenAid smooth top stove. The burners cut on and off. More off than on making cooking really slow. What can we do to get it fixed?
We just moved into this house and all kitchenAid appliances were alreadyin the house
    Prodigy:
    An expert who has answered 500 questions.
  • Kitchen Ranges Expert
  • 644 Answers
You understand, of course, that that is how the temperature of the smooth-sop elements are regulated - by turning on and off. When the setting is low, they WILL be off more than they are on. And as you turn them up higher, they will be on longer and off shorter. At High, they should be on 95% to 100% of the time. If not, then you've got a bad control (also called an infinite switch).
Posted on Nov 27, 2014
SOURCE: ceramic/glass top stove
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
Posted on May 10, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
appldoctom
  • 311 Answers
SOURCE: Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Posted on Jan 02, 2009
SOURCE: My kitchenaid superba has the control lock stuck
the control lock shows up on my stove how do i get it off.
Posted on Aug 17, 2009
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
My smooth top burner will not work
The #1 most likely problem is that you don't have 240 volts to the unit. Your clock and lights will come on but not the burners or the oven elements. Turn off your breaker and then back on. If this doesn't correct the issue...#2 Check your cord and the terminal where it attaches to the stove for a burnt connection, WITH THE POWER OFF!!! #3 Call a technician.
Dec 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Cleaning of stove top
I assume you are talking about a glass smooth top stove. Use any of the liquid polishing type cleaners made for this use. Regular use leaves a build up that makes it easier to clean without streaking.
Jun 29, 2008 | Cooktops
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
