Is there a separate video out or HDMI out for the DC H 6416 DVR that can be used for picture in a picture on the widescreen TV?
ginko
  • 19396 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Go to settings on PS3 and sound settings and set them to HDMI.
If the above did not work, try a auto reset, with unit connected. Hold the PS3 power button down and wait until you hear 2 beeps. The PS3 will automatically search your input/output channels.
Posted on Jan 28, 2009
  • 119 Answers
SOURCE: no dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Posted on Feb 25, 2009
SOURCE: no sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Posted on Mar 23, 2009
  • 40 Answers
SOURCE: No video from RX-V863
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: I would like to hook up my components without
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Posted on Oct 18, 2009
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
I have a vip622 with hdmi hooked up. no video or audio
Get a replacement receiver and see if this does not resolve the issue. I expect it will though. In the interim try a different port on the tv if you have multiple HDMI inputs and another HDMI cable if you have one available just to ensure that our suspicions are correct.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 28, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Can an adapter be used to connect this unit to a sony hd ready tv. The sony has the round connector for hook up and not the square type. I want to hook up a DCT 3400 Series High-Definition DVR
If your Sony TV is hd ready you have a number of choices of connections you can use. On the back of the DCT 3400 you have regular AUDIO and VIDEO connections, the separate Y, Pb, & Pr connections (both of these use the regular RCA style connectors), RF in (which uses the standard cable connection), and the HDMI connector, which uses a special flat ribbon style connector. Your Sony should have all of these types of connectors on the back of the TV. The separate Y, Pb, & Pr, or HDMI connectors will give you the best picture.
Aug 08, 2009 | Televison & Video
Connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Mar 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
44 people viewed this question
 Grubhead
Grubhead
