My machine ir105 .... margin is error how to fix ?
How to fix?
    Sergeant:
    Champion:
  • 324 Answers
Depending on the error, change the margin setting for the document, or change the printing preferences for paper size/orientation.
Posted on Nov 15, 2014
Ir105 canon model error code E000068-0000
Hi Mohammad.
There is an error in the high-voltage output to the separation charging assembly.
An error (leakage) to the high-voltage output to the separation charging assembly is detected.
Check if the transfer charging assembly and separation charging assembly are mounted properly. - Check if the connector (J722, J723, J730, J734) of the HV-DC PCB and the connector (J741, J742) of the HV-AC PCB are mounted properly. - Replace the HV-AC PCB. - Replace the separation charging assembly. - Replace the pre-transfer charging assembly. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Canon Imagerunner Ir 105 Copier Printer...
Tip
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
Canon 105 error code E 000220-0000
Here is the information I found online explaining the error code above:
http://www.copytechnet.com/forums/canon/5926-canon-ir105-error-e000222-0000-a.html
Jul 21, 2016 | Canon Office Equipment & Supplies
I use my canon IR105 printer, suddenly it comes error code like E000005-0010. i don't know how to fix it. soo please someone about it? plzzz give me solution
These MFDs should have proper power supply , next adequate operational area with air ventillation and third paper trays should be fixed correctly , dry paper to be used
Jun 24, 2015 | Canon Office Equipment & Supplies
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
I found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
k24674
jasbo
jasbo
