It doesn't want to reset my password - Computers & Internet
  • 63 Answers
You have to log in as an administrator
Posted on Nov 15, 2014
When i put in default username and password says its not authorized
Try admin in user anme and admin in password.
If that doesn't work then try admin in only password, leave the user name blank.
If that doesn't work then try some different passwords that you use often.
If nothing is working then you will need to reset the router.
Once you reset the router, you will lose all the settings on the router and you will need to reconfigure it.
See How to setup Linksys router
Apr 23, 2012 | Cisco Linksys EtherFast Cable/DSL Router...
Tip
There's a way to reset Administrator password and it doesn?t involve...
How to Crack a Windows XP Administrator Password
(Before you continue Read the Updates at the bottom)
This is only for educational purpose it is a simple way to Hack the Window XP Administrator Password and also get away with it. To Hack the Window XP Administrator Password not many steps are involved especially if you already have a knowleged of working with the DOS prompt.Here are the steps involved to Hack the Window XP Administrator Password .
Go to Start –> Run –> Type in CMD
You will get a command prompt. Enter these commands the way it is given
cd\
cd\ windows\system32
mkdir temphack
copy logon.scr temphack\logon.scr
copy cmd.exe temphack\cmd.exe
del logon.scr
rename cmd.exe logon.scr
exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here isYour are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr. andSo basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this commandnet user passwordExample: If the admin user name is clazh and you want change the password to pass Then type in the following commandnet user clazh passThis will chang the admin password to pass.
Thats it you have sucessfully hacked the Window XP Administrator Password now you can Log in, using the hacked Window XP Administrator Password and do whatever you want to do.Here are the steps involved to De Hack or restore the Window XP Administrator Password to cover your tracks.
cd\
cd\ windows\system32\temphack
copy logon.scr C:\windows\system32\logon.scr
copy cmd.exe C:\windows\system32\cmd.exe
exit
Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click Yes to overwrite the modified files.
on Jan 20, 2010 | Microsoft Windows XP Professional With...
Tip
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 11, 2010 | Computers & Internet
Pass word doesn't work
If your Yahoo account password doesn't work, you will have to reset the password by using the Yahoo password reset wizard.
To open the password reset wizard, click here
Then on the page which opens, select "My password doesn't work" from the options and click Next.
Enter your email id and also identify and enter the security code displayed in the captcha box.
Now click Next button. On the next page, select the alternate email id or the answers to the two security questions which you have provided while registering the email account.
You will then receive a password reset email from Yahoo on your alternate email address.
Follow the instructions in the email to reset the password. Hope this solves your problem.
For more help and clarifications, please feel free to reply to this post.
Thanks for using FixYa
Aug 01, 2011 | Yahoo Mail
My phone has locked up and i forgot the password
If you forgot the password,there are many software to retrieve the password and if it doesn't work then go for resetting your mobile..try prounlocking to get master reset to reset your mobile if software fails to work..
Jul 08, 2011 | Cell Phones
Tip
There?s a way to reset the password and it doesn?t involve reformatting and...
If you have only one Admin account in Vista and have forgotten the password for the same and dont want to reinstall the operating system and land up loosing all your data, this tip is for you.
1) Restart the PC with the Vista Boot Disc.
2) Select Repair Your Computer option
3) Select the Command Prompt
Or - If you dont have a Vista Boot Disc then boot your PC to DOS using any Dos boot disk or other O/s disc.
4) goto "C:\"
5) Navigate to C:\Windows\System32 ( cd c:\windows\system32)
6) Now we will rename the utility manager to cmd.
Type the following commands,
- ren cmd.exe cmdold.exe
- ren utilman.exe cmd.exe
exit
7) we have renamed it successfully.
8) Restart the PC without the disc, reach the screen where you are asked for you password.
9) You will see a white blue icon on bottom left.
10) Click on the icon and CMD will open up, type the following command in CMD.
- net user administrator /active
exit
11) Restart the PC, and you will find you have one more administrator account
12) logon with the new account, goto user accounts and remove the password for your old account.
13) restart the PC with the Disc again, and goto the command prompt as we did in the step 1-3.
14) type the following command,
- cd c:\windows\system32
- ren cmd.exe utilman.exe
- ren cmdold.exe cmd.exe
15) restart the PC, and logon to your own account, open CMD by going from start menu.
16) type the following and restart the PC.
- net user administrator /active:no
17) restart the PC and now you only have one account and thats your own account.
on Dec 15, 2009 | Computers & Internet
My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
Regards,
JJ
May 15, 2011 | Compaq Evo D500 PC Desktop
Encore 802.11G, i forget my password
This is how you reset it, You need to press and hold the reset button for 15 seconds while the power is ON, that should reset it back..
Hope that helps..........
Sep 15, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
