Question about Kenmore 6.7 cu. ft. Electric Dryer
My he2 dryer is not heating, what should I check first?
    Problem Solver:
  • 15 Answers
If it's electric, you have a bad heating element, probably need to be replace, it's the same as a hot water heater
Posted on Nov 19, 2014
Dryer will not heat when using any of the heating cycles.
first check element, then is it isnt broken check safety fuse on element assembly for continuity theres an other termal fuse right of the fan assembly all accesible with the front panel off
Feb 22, 2015 | Kenmore Ap4327152 Motor Control Board for...
Kenmore dryer he2
It could be the belt that spins the dryer is slipping, probably needs to be replaced.
Jul 22, 2014 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
My kenmore HE2 is not drying clothes. It turn s on and spins clothes but does not have heat. It is an all electic front loading dryer
If the dryer is not heating at all the three things that you want to check are going to be the heating element, the high limit thermostat and the thermostat. The high limit and the normal thermostat are going to be located on the heating element itself. All of these can checked with a volt meter set to check continuity. To access these depends on if the dryer has a two piece front or a solid front.If solid, Then you will just remove the back of the dryer and the heating element and thermostats will be located on the right hand side as your facing it, If a two piece, you'll need to remove the kick plate and the parts will be located on the right side once again. Just remember to unplug the machine , 220v hurts, trust me.
Aug 31, 2012 | Kenmore Dryers
Dryer does not heat up when drying. Tumbler works but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././
May 03, 2011 | Kenmore HE2 Plus Front Load Washer
I have kenmore he2 dryer. it works fine except stopped heating. how long should heating element last? what else should i check?
heatman101][
\[0-
Mar 31, 2011 | Kenmore 62602 Electric Dryer
Electric Kenmore dryer warms air but not hot Machine is front loading HE2
Hello there:
Please try each of these solutions i will provide below ok?
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct INSIDE the back cover panel.
The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 26, 2010 | Kenmore Dryers
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 6.7 cu. ft. Electric Dryer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
