Question about Vacuums
Drum needs push to get started and will then turn. It doesn't matter what load is in the drum.
Have checked the belt and there is no obvious sign of slack or deterioration. Do these models have starter capacitors?
There will be a Starter Capacitor. Possibly strapped to the Motor.
Posted on Nov 17, 2014
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: The belt keeps slipping off so the drum won't turn
replace the bel, is worn, put a new one. Of course before try to adjust the tension of belt, for moving a little the motor.
God bless you
Posted on Sep 23, 2012
SD Tech
  • 14553 Answers
SOURCE: change drum belt on a 38AW tumble drier
A dryer in the vacuum area? I will give some advice here:
Google the model number with "how to replace belt" and if lucky you will find a You Tube video that shows what you want to know.
I did this on more than one dryer I have owned and it may take some dismantling of the dryer that the average person cannot do, consider at least talking to a repair shop to see what it costs to be done right the first time and in your home.
Posted on Dec 18, 2012
Beater bar wont turn replaced belt didn't fix the problem
you may have to take the beater bar off and clean out the hair,and string off of both ends, thats where the bearings are.
Jun 21, 2015 | Eureka 5856BVZ Boss Bagless Upright...
I have a Hoover power max self propelled vacuum. The belt that goes to the self propelled part keeps slipping off. I've had the belt replaced, but the problem persists. What can be wrong? I've taken it to...
You may have a bad brush roll,or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Goodluck,
Please don't forget to rate the oslution
May 01, 2008 | Vacuums
Change drum belt on a 38AW tumble drier
Dec 18, 2012 | Vacuums
God bless you
Sep 22, 2012 | Vacuums
The drum is not turning when I the vacuum is on. I have good suction. What should I do?
by drum I take it you mean the beater bar on the bottom? I would check the belt and probably replace it. remove the screws holding the very bottom of the vacuum on and remove the access plate / cover. you should see the belt or whats left of it.
Jan 31, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Replacing belt but brush does not turn
Are you sure that you have the right size of belt? This is the correct belt:
Riccar 8850 Belt
Dec 16, 2009 | Riccar 8850 Vacuum
I have a dirt devil featherlite plus and all of the sudden it started pushing hard and smells hot. I cleaned the roller, changed the bag, checked the belt. The belt is a little wore, but not bad.
If it is pushing hard then you still have a belt problem. It may not be broken but the belt is stretched out too long and will not turn the roller brush fast enough to make it push easy.
Nov 27, 2009 | Dirt Devil M085500 Featherlite Plus Bagged...
Bissell 6579-2 bagless vacuum. Beater bar siezed up. motor turns. took bar out, no movement from either end cap on bar.
1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
Mar 16, 2009 | Vacuums
Brush won't turn
The belt may look ok, but if it is more then a few months old, then it has stretched to where it won't turn under load, just slips. If it is very tight feeling, then check down where the pulleys are, the V belt has a black roll that maybe jammed and not pushing against the V belt when the handle is in the down position.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem putting on flat drive belt on Hover Vaccun cleaner model # U6434-900. Also how do I get the belt on? Do you have tool to help put the belt on.
the best way is to use an flat blade screwdriver. Attach to motor first than but screwblade into belt holding it aginst the brush holder drum and roll the brush forward inching the rubber belt onto the spendle that drives the belt
May 09, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
