I bought a remote control eagle star pro 53-0307 and I followed the directions to set up with my rand TV and doesn't work . I bought it at AAelectronics . Can you help me ?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Try a code search procedure. If the remote control will match with your TV, it will synchronize by this method. If not, there is no other way than buying an other one.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search this Blog" window, and press Enter.
Posted on Nov 16, 2014
SOURCE: Innovage Jumbo Universal Remote Control
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Posted on Aug 04, 2008
SOURCE: Remote control code Tevion TV
Goto. www.medion.co.uk - pick support, enter model number 83388 and you'll get access to the manual
Posted on Dec 04, 2008
colin12
SOURCE: lost directions for universal remote control
sent to me by nextech....
Save Code list for future reference. Refer to the setup procedure below and look up the 4 digit code for your brand of TV, VCR, etc., from the list below.
1519001B, 1519002B, 1519003B, 1519006, 1519007 CL
Refer to the Owner’s Manual for your remote for more information.
Direct Code Entry
1.
Press and hold the
SETUP button until the
red indicator stays on,
then release the SETUP
button.
2.
Press and release
the desired Mode button
(TV, VCR, etc.). The red
indicator blinks, then stays
lit.
3. Enter the 4 digit code from
the code tables. Note: after
a valid code entry, the red
indicator turns off. For
an invalid code, the red
indicator flashes.
4. With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of
the other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for
3 seconds.
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the
button.
3. Press and release the
desired Mode button
indicator blinks once, then
stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in
step 3 of Direct Code Entry.
Then follow the steps above
for Code Search.
Direct Code Entry
1.
Press and hold the
button.
2.
Press and release
lit.
indicator flashes.
brand.
3 seconds.
Code Search
to the right.
be controlled.
button.
desired Mode button
stays on.
for Code Search.
answer found at support@orbyxelectronics.com
Posted on Jan 15, 2009
  • 9 Answers
SOURCE: UMC J20/1U12G Set - Need Remote Control Code
http://www.remotes4u.co.uk/show_models.php?brand=UMC
Posted on Mar 10, 2009
SOURCE: pro team remote control
1. Press and hold SET button and press and hold device key at the same time, when l.e.d. lights release both keys.
2. Enter the code for your device.
3. Press power on the remote
If device can be controlled then code has worked if not try another code.
4.Press any device key to quit setting procedure.
Posted on May 12, 2009
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Oct 07, 2012 | Toshiba SE-R0305 Remote Control
The power went out and my RCA tv needs to have the time set to continue watching. But the remote does not work, and I can't access the menu from the tv
Hello
If the remote control doesn't work, just buy one RCA RCR model universal remote control. Without remote control, you can't set the time to this set.
Mar 04, 2012 | RCA Televison & Video
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
I am not getting any picture from the tv. dvd and radio is working fine.
press the AV button on the remote control & if it doesn't work, look for the TV button on the remote control; & if it doesn't work again, check the booklet that comes w/ the tv upon purchasing it or bring your tv to where you bought it & make use of the guaranty voucher for them to fix it for free, (try those buttons first before bringing it back to the store).
May 12, 2011 | Televison & Video
Samsung UN46D6300 TV not in Logitec Harmony 700 remote database. Need IR code/s to enable controls (especially TV input source selection). Learning mode was only partially successful for power, volume...
When i went into the Harmony software, your TV did come up. If these codes aren't working try a different model Samsung (like UN46D6000). All new Samsungs use the same code set. If this still doesn't help, go to "Devices"->"Settings"->"Adjust Inputs"->"Method 3". Follow the directions from there. Something else that may help is Samsung calls it the "Source" button, Logitech calls it "Input x".
Apr 28, 2011 | Samsung Televison & Video
Find a code for remonte control eagle star
i forgot my code for eagel star U/Cto work with my pansat2700a
Dec 28, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
