Question about Dome 4 CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH
Wich wires go where in the bullet color camera cx520bcwa
How to wire and what is the color coding on the wires
these types of cameras normally have 3 connections. one if for the power, prob DC12V. another is the video out, which needs a BNC connecter, the third is for the lens if you put one on the bullet camera. power has a (-)(+) and sometimes G (ground)
Dec 19, 2012 | Cla Mini Bullet Security Camera Color...
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
Dec 07, 2012 | Samsung Soc-a101 Hi-res Outdoor Bullet...
I got a fuel pump and the wires that goes on the fuel pump are all white and the ones from the tank are difrent colors. i wana know wich wire goes on wich one?
I believe they should be pretty similar plug-ins (straight- straight or square-square). Cut one wire at a time and Wire them accordingly.
Mar 18, 2011 | 2002 Buick Century
His
01 - Are you Install Paperless ? 02 - Kindly Check his Wire's . Some time Wire Damage . 03 - Try to Change with any Other Camera . With Same Wire's Or Camera with Different Receiver .
Reply me for More Info . Shah Zad Rashid . IT Hardware/Software Engineer
Feb 16, 2011 | CSi Speco Speco Tech Cvc-627mr Color...
Need audio diagram Wire system Subaru impreza TS 2002
go to your local audio retailer and bye a adapter plug for your radio to the car they are cheep and eliminate any need to cut wires
Mar 21, 2009 | 2002 Subaru Impreza
I bought the LG LHT854 and i dont know how to connectthe speakers because i dont know which ones are the front speakers and rear speakers, all 4 speakers are the same and i dont know how wich is wich..
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
Dec 24, 2008 | LG LHT854 Theater System
How can i get the original color of the li tag bullet ?
sorry, meant to choose solution rather than clarification.
Nov 06, 2008 | Computers & Internet
Need diagram for signal wiring
there are only 4 wires going to your signals take your signal lever out and look at the color of the wires and then take yoiur tail lamp out and check the colors that shoiuld tell you wich wire goes where. but if you need to run wires just run them from your lamps to your steering colom and there should be a switch there with one hot wire! it should have 2 nipples o it and just connect to the npples and flip the switch to check wich side is wich and adjust!
Sep 08, 2008 | Jeep CJ7 Cars & Trucks
USB Cable
Hold the camera as if you were taking a picture. Turn it to the left so the skinny side is towards you. At the top, the is a small place that says, "DC IN." Use your finger to pull down at the top of this area. That's it.
Dec 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Dome 4  CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH Logo
62 people viewed this question
Top Dome Home Security Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Dome Home Security Expert? Answer questions, earn points and help others
