Question about Measuring Tools & Sensors
I CANNOT GET MY OUTDOOR TEMP, TO CHANGE, HAS NEW BATTERYS AND POLARITY IS CORRECT. PLEASE HELP, THANX
    Scholar:
  • 99 Answers
Hi Jim, what make/model station do you have? Normally there is a search function on the main unit to find the outdoor unit. After that they should sync and the outdoor temperature will reflect the temperature of where the outdoor sensor is located.
Hope this helps.
Posted on Nov 15, 2014
My 6yo NatGeo super weather station has quit transmitting outdoor temp & humidity info. The display is present and correct for all other categories. Changed batteries, no help. Any ideas?
  • Remove all batteries
  • Install batteries in transmitter and wait for it to begin sending data
  • Install batteries in receiver. You should see temperature and humidity displayed
Jul 18, 2017 | Measuring Tools & Sensors
Outdoor temp doesn't show on my LaCrosse 8349
try changing channels on all sensors and the receiver.. You will have to go through a wait time as before. This worked for me last year, but mine eventually failed completely this year
Jun 14, 2017 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
Outdoor display doesn't work
My clock display of the outdoor temp is only blinking and not display the the temp. I have the senser put in in outdoor window. The senser shoes the temp but is not carried over to the clock. Ive put in new batteries and have the senser in the correct distence from eachother. Why is the clock contunue blinking outdoor temp.?
Jan 15, 2013 | Audio Players & Recorders
Equity Wireless thermometer Outside temp never registers
From their instructions:
RESTART:
  • RESTART DISTANCE: For best results please bring the outdoor sensor in the house and place 5 feet from the display unit.
  • REMOVE POWER: Remove batteries from the sensor. Next remove batteries (and/or a/c cord) from the display.
  • DISCHARGE ELECTRICITY: With the power source removed, press one of the buttons on the display at least 20 times to clear all stored power. Please do this even if the display is blank to remove any remaining power. Verify the display is blank.
  • UNPOWERED FOR 15 MINUTES: It is important with most of our displays to remain without power for at least 15 minutes.
  • NOTE: Failure to allow a display to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing segment on the display. The instruction manual describes a setup for a new unit that has not had time to build up stored power.
  • BATTERIES: Please be sure you are using fresh batteries tested to a minimum of 1.48, on a voltmeter that reads in numbers.
  • SENSOR FIRST: Place batteries into the outdoor sensor first. Make sure they are installed according to the polarity diagrams in the battery compartment.
  • DISPLAY NEXT: Install batteries (or a/c cord) into the display according to the diagram in the battery compartment.
  • CONNECTION: Allow the sensor and display to remain 5 feet apart for 15 minutes to establish a strong connection. Do not press buttons at this time. You should see a reading on the outdoor temperature area in the first minute.
Gary
Jan 07, 2011 | Garden
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
Polar F7 no signal from transmitter to watch I purchased this about 12 months ago
One of the units probably needs a new battery. They bot have batteries. A year is about the time that they need replaced
Oct 23, 2009 | Polar F 6 Heart Rate Monitor, Coal
How to replace the battery on the polar f55 watch. I have the back off but do not see how to remove the battery.
The idea that you cannot change the battery yourself is nonsense.
Remove the 4 screws from the back. (A size #000 screwdriver works well.)
To remove the battery latch, stick a small, flat-blade screwdriver in the hole shown below:
Pry the metal tab away from the battery and the latch will release.
The battery is a CR2032. Note that the + is face down. To replace the latch, just push the open end back into place. It will click closed easily.
When replacing the back cover, take care to make sure the seal is positioned correctly inside the groove.12_8_2011_4_41_24_pm.png
Replace the 4 screws and you're done!
Sep 30, 2009 | Polar F 6 Heart Rate Monitor, Coal
Temp guage hot & won't start
Simply replacing the battery can NOT cause the problem you describe. I suggest you check the battery cables (polarity) to be sure the battery is installed correctly... then check the battery cables to ensure they are properly connected and no damage is evident (negative - to negative - and positive + to positive +). Replace cables as needed.
Apr 18, 2009 | 1994 Hyundai Excel
Measuring Tools & Sensors Logo
392 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
