Question about Cell Phones
I had opened a network share from a borrowed lap top to fix windows on my PC, unaware that i was actually opening a share to my iPhone a malicious virus (idaemon) was deliberately placed on it to hack into & send my data information (as soon as the virus got into my phone the lap top had crashed, leaving me with no known way of disabling the shared network, the virus used in combination with a mime attachment sent to me via an email now allows my iPhone to be remotely controlled by my ex partner is sending text messages that i cannot see & don't know about until i receive a visit from a friend & changes my wall paper yo pictures of me & him. how do i disable the shared network without access to the original opening source?
What should I do to enable a terminated a network to connect Internet to my Lap top?
You can open Network and shareing menue and search for any internet connetion in the area or you can plug a ethan cable in the computer and it will do it automaticly
Mar 12, 2015 | Toshiba Satellite C655d-s5130 Laptop, For...
How can I share an internet connection using a PC?
On your PC, open up Control Panel, click on Network And Internet, Click on Network and Sharing Center, then on the left side click on Change Adapter settings. On the tethered iPhone connection, right click and select Properties. On the Sharing tab, check the box to share that devices connection with other devices on the network. Click OK and close out of the open Network connections window. Connect your ethernet cable from your computer to your router's Internet/WAN port and run the router setup. If the setup does not detect the network correctly, configure it to use DHCP.
If the shared connection method doesn't work, try selecting both your LAN and iPhone connections in the Network Connections screen, right clicking, and selecting Bridge. Then proceed with instructions as written.
Jul 19, 2014 | Apple iPhone Smartphone
How to configure the access point to the lap top ? with out CD /driver ?
Assume using windows In control panel find the router. Vista look for the network and sharing centre), open this up and double click on network, you will see your router icon.
Right click
on this and view device webpage.
The settings and options can be found in there
Dec 29, 2010 | NetGear WG602 802.11g/b Wireless Access...
What do I need to successfully go wireless. I have a pc and a mac book pro and want them to talk to each other. the PC has windows xp and some files can be shared.
get a wifi router. assign ip as 192.168.1.1 with the network name as My wifi. install a wifi card on ur pc. connect ur pc to the wireless network. similarly connect ur lap to the wireless network.
assign following ip's for ur
pc - 192.168.1.5
lap - 192.168.1.10
in ur pc run--> There type \\192.168.1.10
lllry from ur lap using pc's ip.
this is how u can network ur pc and lap wirelessly
Jul 21, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
KVM Switch
I don't no how did you try.
If your both lap are connected in any way you can share printer to both your lap. Please try the following steps:
Step 1): Install the printer drivers to your first lap.
Step 2): Connect your printer to your first lap and turn it on.
Step 3): Navi gate Start -> Printer and Faxes
It will open the Printer and Faxes window including all your printer installed.
Step 4): Right Click on the printer icon whic you want to share and select Sharing.. from the pop-up menu appeared.
It will open your printer properties.
Step 5): On sharing tab click on Share this printer radio button and give a Share name also tick the list in the directory.
Step 5): Clik on Ok
Now your printer is ready to share to other computer in your network.
Step 6): In the second lap navigate Navi gate Start -> Printer and Faxes
Step 7): Click on Add printer to left panel of the window
Step 8): Click Next
Step 9): There will be option Local or Network select Network and click Next
Step 10) Again Next, The find printer dialog will be open. Type the firs 1 or 2 letters of the your printer name which you have given in share name of first lap and then clik find.
Step 11): The printer will be listed in a list Select and click ok and click on next in next dialog.
and now you can enjoy..........:))
Thanks
Iqbal
Mar 19, 2008 | Computers & Internet
Router wireless
Do you have the router setup to provide either WEP or WPA encryption? If so, you will need to provide that Encryption key (think password) for your SSID (the wireless network you connect to).
If you then can connect to the router, but still can't get on the Net, you may need to go into the Advanced settings of that particular wireless network (Windows XP - open Available Wireless Networks, and click on the last item on the left Advanced Settings - then click on the 2nd tab - Wireless Networks - pick your network in the box at the bottom, and change one setting from "Open" to "Shared". You should then be able to connect properly.
Jan 28, 2008 | Linksys Wireless-G WRT54G Router
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
