Question about Garden
Echo pb500 t has no spark - Garden
    Genius:
  • 2,494 Answers
C.D.I unit faulty or spark plug fouled up.
Posted on Nov 15, 2014
2 Suggested Answers
  • 320 Answers
SOURCE: echo pb500 only runs with choke open
I'm not to sure about the question. But you say it runs with the chock open. Your engine will only run with the chock open. Can you clarify?
Posted on Mar 05, 2012
Location of spark plugs on a 2000 Toyota Echo
a repair manual will probably tell you. it has maintenance schedules, models of commonly replaced parts (spark plugs, oil type, weight etc)
http://www.papertownspdf.com/downloads/toyota-yaris-echo-repair-manual-1999-2010/
Dec 29, 2016 | 2000 Toyota ECHO
Where is the coil located on a echo handheld pb255 gas blower?echo
just follow the plug wire right to usally under cylinder or near recoil houseing
Aug 17, 2014 | ECHO, Inc. PB-251C Handheld Blower
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Spark plug gap size for 02 toyota echo
Spark plug gap size for 02 toyota echo?
NGK BKR5EY Spark Plug Gap: .031 inches or .8mm
Feb 08, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
When to change sparks plugs into my echo 2000
Spark plugs are replaced when the electrodes are found to be corroded, burnt, cracked or oil fouled.
Normal spark plugs need to be replaced every subsequent 30,000 Km.
Iridium - tip spark plugs are replaced every 80,000 Km.
Mar 26, 2013 | 2001 Toyota Echo
Echo pb500 only runs with choke open
Feb 27, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My echo pb-2100 gas blower has no spark and wont start whats anyone has an idea whats the problem
no spark sounds like the coil, but check the connections and any corrossion in the wires
Oct 13, 2010 | ECHO, Inc. PB-251C Handheld Blower
How can i test the ign. coil on a echo HC-1500 and also check the flywheel i have no spark and i have unplug the kill switch
pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Sep 23, 2010 | ECHO, Inc. 20 In. Double Sided Hedge...
Echo GT 2000 does not have spark and will not start. Checked fuel lines, ok, replaced spark plug, ok. checked for spark at plug, no spark.
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Jun 20, 2009 | Echo Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
