Question about NEAT Office Equipment & Supplies
Incomplete scann only a thin strip of the document or receipt appears in the file. Have cleaned and calibrated
    New Friend:
    Problem Solver:
  • 18 Answers
Change your scanner
Posted on Nov 23, 2014
2 Suggested Answers
SOURCE: Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Posted on Mar 10, 2008
Blank scan with neat desktop scanner
Connect the scanner to a different computer.
If you get the same result, then the scanner is "dead".
It's moving the scanning-head, but not detecting (or not transmitting) any "non-base-line" information.
Either that, or you have changed the CONTRAST and/or BRIGHTNESS settings to "wash-out" the image -- like looking at a "cream" coloured piece of paper in bright sunlight -- it may look "white".
Feb 03, 2014 | The Neat Company NeatDesk Desktop Scanner...
Verticle lines appear on document when scanning through document feeder. No verticle lines on document when it is scanned face down on the glass. How do I clean the document feeder?
There is a thin strip of glass next to the main platen glass, where documents fed through the feeder are scanned. You most likely have Wite-Out or some sort of debris stuck to the glass. You can probably wipe this residue off, but if you need to clean that strip of glass, use alcohol and a lint-free rag.
Oct 07, 2010 | Brother MFC-7420 Laser Printer
Copies run through the feeder have black line on them, copies on glass & faxes are okay
Clean the ADF scanner glass. This is the small strip of glass that is just to the left of the large glass. Normally there is a label on the machine right by this glass that instructs you to clean this strip of glass whenever streaks appear when using the ADF or Automatic Document Feeder. Sometimes toner/dirt gets stuck on this strip of glass so clean it well using a soft cloth with some glass cleaner.
Good Luck and Thank You for using Fixya
Apr 29, 2010 | Ricoh Aficio 1035 Copier
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
97 people viewed this question
Top NEAT Office Equipment & Supplies Experts
handyguy54
Level 1 Expert
Austin Ron
Level 1 Expert
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
