Question about Boating
How do I winterized a 40hp evenrude 2stroke - Boating
  • 427 Answers
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Posted on Nov 15, 2014
    Problem Solver:
  • 14 Answers
Safety First Before you begin to winterize your boat's motor, remove the negative battery cable from the battery. You'll need a 5/16-inch wrench to loosen the nut on the negative lead. You should also remove the propeller from the propeller shaft. Send the propeller to a prop shop for repair and refinishing
Lower Units and Outdrives Water that freezes in your motor's drive can wreak havoc with the drive system of both inboards and inboard-outboards. The water gains access to the drive unit of an outboard motor through faulty water pump seals or prop shaft seals. Changing the lower unit or outdrive oil prevents this. When you drain the oil, look at the color. If it's milky, you have a broken seal that's allowing water to leak into the drive system and the seal needs to be replaced. Feel the oil -- rub a bit of it between your fingers. It shouldn't feel gritty. Some very fine metal particles in the oil are normal and usually aren't noticeable. Gritty lower unit oil means abnormal gear wear
Cooling System Your boat and engine operating manuals tell you the type of cooling system your motor uses. Almost all outboards rely on a raw-water cooling system. The intakes for the system are underwater when the boat's in the water. The intakes pull water into the engine's water pump for distribution throughout the engine. Winterizing these system means cleaning the strainers on the inlet ports. You must replace an outboard motor's water pump outdrives as part of the winterization process.
Fuel Systems Change the fuel filters when you winterize your motor. Most boat motor manufacturers recommend you change fuel filters every 500 hours or once a year. Cold temperatures cause the residual fuel in filters to gum up. If water trapped in the filters freezes, the filter expands and can damage fuel lines.
Automated Winterization Evinrude's E-TEC series outboards feature a self-winterization feature. You connect the outboard to a water source, start the engine and move the throttle to the high-idle-winterization throttle position. The motor's speed will vary and the engine will shut down after about 30 seconds, fully winterized. Whether this feature will eventually appear in other outboard motors remains to be seen. In the meantime, your motor's operator manual contains all the manufacturer's recommendations on preparing your motor to endure winter's inactivity.
How do I winterized a 40hp evenrude 2stroke - winterized-40hp-evenrude-2stroke-onjfhl0a5s2gefnhws5z0tk3-2-0.jpg
Posted on Nov 22, 2014
Can a sevearly carboned piston be cleaned without rebuilding the whole motor. 2003 40hp 2stroke
Hey Kyle,
Yes, its possible, but difficult to accomplish due to the carbon getting into everything... How do you know the pistons are severely carboned?
...Please reply to me and we'll work through this....
. ( I am a factory trained mechanic with 45 years experience)
Jun 14, 2017 | Cars & Trucks
Is it 2 stroke or 4 stroke
look at the engine and if you have a cap to remove and put engine oil in then check with a dipstick then you have a 4stroke if you done then a 2stroke ! do you put 2stroke oil in the fuel , if yes then you got a 2stroke !!!!
Mar 23, 2015 | Boating
My older Evenrude 30 elo 689 L 418232, How do I winterize motor?
The main concerns are:
1. Draining and/or running all the fuel out
2. Fogging the engine with protective oil (fogging oil is available)
3. Remove the prop. The splice could use some lube and the number 1 cause of oil leaks is fishing line wrapped around the prop shaft. You don't fish? others do.
4. Hang the motor vertical (normal running position) should drain all the water out.
Nov 05, 2014 | Boating
How to add gear oil to a 1989 , 40hp , 2stroke merc. I have removed the vent bolt and above it to the left is a bolt. This is not the same as the one I removed. But is this the one I remove.
you remove the lower bolt get oil ready then remove then remove vent adding oil in bottom hole till full .replace upper screw with bottle still over lower hole prevents running out . then put in lower screw usually has a magnet in it .
Sep 28, 2014 | Boating
Evenrude point gap
I will try to help. You should be able to rephrase your request on the Browser and look for Specs and your motor info. Create different phrases until you get the answers you want.
I have a Johnson 15HP and it may even have electronic sensors for points. I remember a 1950 Mercury 40HP which was around 18-20 thousandths. In a jam a matchbook cover would be a close gap. Seem to remember gaps were tighter with Magneto power because spark was weak.
You can try to relist on this site under Boats catagory. I hope my solution helps.
Jul 04, 2012 | Cars & Trucks
No reverse on yamaha 40hp 2stroke outboard
hi, on the shaft housing (a litle above the cavitation plate) there is a rubber plug, remove it and check if the conector of them 2 rods is in the correct position . Adjust if needed
Sep 13, 2011 | Yamaha Boating
I have a 1997 Yamaha 40hp....C40PLRV without oil injection. My Sealoc manual calls for a 100:1 fuel mix. I had a dealer tell me to run 50:1, but it idles rough and is hard starting when cold even with...
Mate.2 stroke motors WITH oil injection run between 100/1 and down to 40/1(rich).With yours being pre-mix,it should run at 50/1 to be safe.Using a good quality 2stroke oil,with low smoke,it should run well.The only thing that may change, is how you use the motor.Slow trolling or running along travelling.A spark plug that is 1 heat range hotter will help burn the fuel/oil mixture if you do a lot of slow running.Faster and /or high speed running,will keep your plugs ok.These are safe guides not to cook up a piston.Hope this helps you
Dec 06, 2010 | Boating
What needs to be done to install a15 evenrude kicker motor on a 1988 lund 4.9 tyee boat with a 70 evenrud
if there is enough space on the transom just bolt it on if not you will need an adaptor plate
May 20, 2010 | Boating
Boating Logo
247 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
