Question about Vizualogic 7 DVD headrest for 2007 Mercedes S Class with Active Headrest Restraint
How to remove headrest on Mercedes 2007 s class
My 2003 c320 drivers seat blows fuse when headrest,recline or memory buttons pushed. Does not blow when forward/rear slide adjust used. Any ideas??
sounds like you have trapped/chaffed wiring under seat or around seat recline hinge, remove seat and have a close look at the wiring. disconnect battery first because airbags in seat and seat belt pretensioners i think are fitted to this car. good look
Sep 12, 2015 | Mercedes C-Class Exterior Pillar Posts...
Where is the control button for the drivers seat headrest on a 2011 Mercedes c 300 class
should be on the door panel along with all the other switches for controlling the seat adjustment
Aug 18, 2014 | 2011 Mercedes-Benz C 300
My headrest are way up I like to get them down
try the switch, if it don't work, help it by hand and hiting the switch at the same time, may need to do it manually
Sep 04, 2013 | 2007 Mercedes-Benz E-Class
Front headrest deployed in my 2007 e350 Mercedes. I was rear ended. No damage to my car but I would like to reset the headrest to its original position. Please help.
to replace that, you might want to just buy a whole new headrest, pull off the old one by holding the adjusments tabs until it comes out, then take the whole thing to part source and show them, they can get you another one or your dealership, then put it back in the exact opposite way you took it out. problem solved.
Oct 06, 2012 | Cars & Trucks
2002 mercedes s430 rear headrest not working.... where is the fuse
fuse should be in one of the locations that owners book sez-or u can find it in a haynes manual or parts store help------------cud be motor or wiring also
Oct 09, 2011 | 2002 Mercedes-Benz S-Class
How do i turn on my fog lights in my 2007 mercedes c230 and how do i lower the electronic portion of the passenger's side headrest?
hi go to your main light switch rotate it to driving headlamps and pull the swithch towards you it should slide out slightly in stages and operate the fog lights
the headrest switch is a button in the center console near the gearshift
Feb 22, 2011 | 2007 Mercedes-Benz C230 Sedan
Mercedes e220, horn, heater fan and electric
Horn and heater may be fuse related. The headrests have nothing to do with fuses. The switch is bad or going that way for the seat or the motors for the headrests are out.
The horn fuse spin it, or replace as corrosion from aluminum fuses cause problems. I suggest replacing them all with new copper barrel fuses. The blower motor fan is a strip fuse on the driver side strut mount in a tootsie roll sized case.
Mar 11, 2010 | 1995 Mercedes-Benz E-Class
Rear headrest and rear dash removal
some are easier to install from the trunk
Jul 01, 2009 | 1995 Mercedes-Benz C-Class
Front power headrest removal
hello,you need to remove your rear seat,,look for your your headrest valve ,there is a lock pin with tension clip in headrest rod ,remove the pin,try to remove your headrest slowly,ty
May 07, 2009 | Mercedes-Benz 560-Series Cars & Trucks
Trying to remove a headrest from passenger seat in 2007 xc90
push & hold button on headrest while pulling up
Feb 19, 2009 | 1990 Volvo 740
Vizualogic 7 DVD headrest for 2007 Mercedes S Class with Active Headrest Restraint Logo
Top Vizualogic Car Audio & Video Experts
xxxxxx xxx
Are you a Vizualogic Car Audio and Video Expert? Answer questions, earn points and help others
