Fuser error is problems
Red light error problems
    New Friend:
  • 24 Answers
Fuser replace is solution. Now that is settled, we can use some details, like make and model And the nature of the problem, please (error messages details)
Posted on Nov 24, 2014
Sir ricoh printer is not working in red light and display in c8 whats problem now tell me
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
IF THI IS A SP200
Apr 26, 2016 | Ricoh Office Equipment & Supplies
Fuser open message not a broken gear
the fuser unit got a thermal fuse on need to replace. it over heat and the the power do not go throgh
Dec 02, 2011 | Brother MFC-8640D Printer
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open
2.no cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
May 10, 2010 | Samsung CLP 315 Laser Printer
My Brother HL 2170W printer has red error light on. It was printing something over and over and I wanted to stop it so I pulled (oh, no!) the paper out and then I guess the red error light went on. I...
There is probably still part of the sheet in the fuser at the back of the machine. The fuser will need to be removed and checked for scraps of paper and/or damage to the temperature sensor and v likely a dislodged paper sensor arm.
Oct 15, 2009 | Brother HL-2170W Laser Printer
Blinking red light with system error H4-00. Help!
The H$ is not a generic toshiba copier error. It usually associated with the smaller desktop copiers only. The H4-00 indicates a temperature problem in the fusing unit. It could be one or more of the following items : thermostat or thermistor or heater lamp or the control board.
You could try taking the fuser unit apart and cleaning it. Try resetting the error in service mode. make sure you are in copy mode.
press the "C" key then the "auto/text/photo" key then the "C" key then the "auto/text/photo" key again. enter "14" then "start" - this will reset the fuser error. IF there is something wrong with the fuser the error will come back again.
Then its time to call you local service center.
Mar 16, 2009 | Toshiba Office Equipment & Supplies
I have just replaced cartridges and am now getting fuser low heat error.
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Jun 16, 2008 | Samsung CLP 300 Laser Printer
ERROR MESSAGE
Yes you have a fuser problem you can try to reset it but more than likely you will need a new fuser or part of the fuser
Contact me if you require more help
Mar 06, 2008 | Canon PC-D320 Copier
Stuck on Red
Normally mean fatal error on this machine you can hold the go button down for a couple of seconds and it might give you a secondary light sequence. Normally if the red light is on and nothing happens the most common fault is the fuser unit is not warming up.
You will have to replace the fuser unit, but this all depends on the second light sequence.
Thanks J
Nov 14, 2007 | HP LaserJet 2200D Printer
k24674
jasbo
jasbo
