Question about Xerox Office Equipment & Supplies
I get mother board or main board failure a lot of times due to fluctuation of electricity.now i m not sure if i should change the mother board all the time or just repair the failed part
Please reply me with my question.
  • 1,147 Answers
When the mother board goes out, you'll get nothing ever again from it. If it comes back usable each time, it won't be your motherboard. Fix the other stuff.
Posted on Nov 15, 2014
My freezer keeps going into intermittent thawing were the fan shuts off. I have checked the four thermisters and it appears that I am not getting a constant reading, but it does fluctuate near the 16
ge fridgs are hard to check.. but I have seen the main pcb cause exactly what is going on with your unit... if this unit has some age on it the pcb would be a good place to start.... does the evap fan run when u push in the fan door switch?? if not replace the evap fan motor at the same time.. it will save you a lot of headaches...... hope this helped....... ken
Oct 09, 2014 | GE Refrigerators
Ups says bypass unavailable
This happens a lot. Your input power lines fluctuate a lot from time to time. You get lags and sags and spikes on the power line. The UPS is just telling you this. Nothing you can do about that. Your UPS is operating normally. You don't really want to put the UPS into bypass during one of these fluctuations do you?
Apr 08, 2014 | Powerware Series 9 9170 UPS System
While driving and holding steady speed, the rpm's fluctuate 200-300 rpm's
How many miles are on this vehicle? Is the engine light on? If so, can you have the codes read? RPM fluctuation can be anything (both caused by mechanical or electrical changes or failure/s). Fuel pressure, engine compression, 02 sensors, worn or sticking TAC unit, vacuum leak, poor fuel quality, dirty or defective MAF sensor, clogged air filter, old spark plugs, excessive exhaust back pressure, stretched timing chain, over due oil change, worn or damaged throttle pedal, or worn out spark plugs. These can all cause your symptoms. Let me know if you have anymore questions.
Feb 16, 2014 | 2005 GMC Envoy Xl
Mother board not working
if your sure it's the mother board. You can replace it. Motherboards are not designed to be repaired by the owner.
Jul 11, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
How do I fix pixelation on my Samsung LCD Flatscreen TV?
Hello!
Looks like pixels are appearing due to the failure of TV's main board. There is no "reset" button at all. the problem occurs due to fatigue failure of solder joints under main board's microprocessor. Technology has changed, but not in our favor! At computer motherboards, there is "zero insertion force" plug, which connects "micro" to the main(mother) board. It allows I.C. chip to be well connected to the circuitry, despite the difference in ambient temperature. Latter makes of TV's main boards using laser soldering of 100+ contacts to flat board via led-free solder alloy. after numerous cold/hot/cold cycles, the alloy becomes brittle and fails to connect all the pins of "giga chip" to the board. Plus: there is no such thing as a cooling fan or, even basic heat sink in most brands. "Disposal" technology! The only way to cure the problem is to replace main(signal) board, if your set is less than 3 years old. If more, there is a possibility of bad capacitors in a power supply. If the set hesitates to start up cold, that's the issue. But...? Couple month ago I did replace main board in 46" Samsung LCD Panel, due to the same reason. Looks like you are up to repair your set. whether it's a panel or D.L.P. the problem is beyond "reset"! It will only get worse over the time. Call for service or give me your model#. I might help you with part search and replacement procedure.
Thanks,
Alex.
Jan 12, 2012 | Samsung Televison & Video
Ever since I bought my new "KIng of the Hill" Ge
so try to install voltage regulator maybe it can affect on the main mother board operation bec. of power fluctuation observe unit after install automatic voltage regulator . if problem recurring mother board have problem or try to check the program setting.
Feb 05, 2011 | GE Profile PFCS1NJWSS Stainless Steel...
I have no power. Printer was priniing and when
Power supply or main board is common failure on these resulting in dead, ....can be from power fluctuations on line, ir spikes on four boards, if you have checked the lead is secure and that the point you are using works ...and there is still no display.... then I'm afraid this is your brother no longer due to the power supply or main board being worth more than the unit itself, sorry bye brother ;)
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
The tint changes colors, green to red to blue, etc. while it is on. What's wrong?
you have a problem with the main controller board. unfortunately, there are no replacements from infocus. sorry.
but try to clean and resolder the edge connector (looks like silver fingers) contacts on the power supply where it plugs into the green plug on the main board. the main board may be getting fluctuations in voltage due to poor contacts.
Oct 14, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Comes on but then goes right back off and power light blinks red and green
hi. this is a main mother board issues with a number of circuit component failures. the power section of this unit is safe but, the main assembly will need to be repaired. the quick shutdown is signaling merging circuitry, due to a heat related issue.
This can be fixed by replacing the entire mother board in this unit.
May 18, 2009 | Sony Audio Players & Recorders
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
