Question about Coleman Gas Fired Mobile Home Furnace, Dual, Position, Direct Vent-95.5A.F.U.E. MG9S Series. 60,000
Coleman mg9s propane furnace. I need to adjust manifold pressure but there is no screw to adjust, instead there is a spring loaded pin and you can only flip the brass cap around to convert from NG to
Coleman mg9s propane furnace. I need to adjust manifold pressure but there is no screw to adjust, instead there is a spring loaded pin and you can only flip the brass cap around to convert from NG to propane.
    Novelist:
    Scholar:
  • 187 Answers
All pressure adjustments are made outside at the tank regulator. The regulator on your valve has been disabled.
Posted on Nov 23, 2014
Coleman propane furnace pilot light goes out
Check propane pressure, also check for water or other contamiants in the propane.
Nov 13, 2013 | Heating & Cooling
Convert coleman furnace model# 7956B856 Serial# 039167560 from propane to natural gas . What do I do to the gas valve and what size orifice do I need ( or drill size to drill the propane orifice out ) .
You will need to get a natural gas conversion kit for your equipment. It will include around three different orifice sizes depending on elevation. Never drill orifices yourself as this is a gas appliance and could kill you. You will have to remove your gas manifold and unthread the existing orifices and screw in the new ones. As far as the gas valve you will need to unscrew and remove the adjustment screw and change the spring located underneath and reassemble. Once changed out you will need to check the manufacturers name plate and adjust the manifold pressure using a manometer. If this is not done having incorrect gas pressure can cause delayed ignition, overheating of the heat exchanger or high carbon monoxide levels. The conversion kit is inexpensive and should take less than an hour to do
Oct 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a coleman evcon gas furnace that keeps giving me an error code (Limit switch open, and sometimes it wont kick on when i get this code, I have replaced the Lower Limit Switch, and workd fine for a...
i hope the heater doesnt come on when a limit switch is open,you really have problems. so a limit is telling you that your furnace it over heating. first check filter and heat vents and returns they must be clean and open. closing heat vent or blocked returns will cause over heating. after chacking this look at firing rate. furnace could be overfired. you would need a "u" gauge to check manifold pressure. your name plate will tell you what this should be. find the tap on the burner manifold or outlet of gas valve. fire furnace and see what it is. 3.5"wc for nat and 10" wc for propane maybe.
Feb 10, 2011 | Coleman Propane Forced Air Heater...
Coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Apr 27, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
What do I need to do to covert from propane to natural gas on 100,000 BTU furnace ? It is a weather king md.80PJ10ECR01
Take your Model and serial number to an HVAC parts house and they will get a kit for you that switches over from propane to natural gas. The spring in the valve is different and the orifices are different. Propane runs about 10 to, 11 inches of water where natural gas is about 2.5 to three. So if you did not change the springs and orifices you will cause the furnace to over heat and posibly catch on fire. These kits are easy to change the orifices just unscrew. The top of the gas valve has cover over the spring and an ajustment screw inside just remove that and pull out old spring and insert new one. Be careful with the springs they are very tiny and not much thicker than human hair. You really need to get someone to set the pressure for you. Feedback welcome Rus
Dec 07, 2009 | Weather King Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Coleman Gas Fired Mobile Home Furnace, Dual, Position, Direct Vent-95.5A.F.U.E. MG9S Series. 60,000 Logo
113 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
