Question about LG LDS5040BB Black Semi-Integrated Dishwasher LDS5040
Dishwasher gives FE error after a few minutes of wash cycle. Error code does not occur when "quick" wash cycle is selected but does for all other cycles.
  • tjsnonn Nov 19, 2014
    There is no number after the error code.
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: LG dishwasher model LDS 5811ST
Do you get any number in error message?
Posted on Aug 03, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
  • 108 Answers
SOURCE: Stops during cycle says error has occurred
doubt he actually back flushed the line. I bet that after he cleared the filter and removed debris under the filter, he started a quick cycle, then after the dishwasher was filled, he pressed the two buttons together that make up "Cancel" , held for 3 seconds and the unit automatically began to pump the water out and prepared to shutdown.
The cancel button can be used that way anytime it is needed.
Hope that helps.
Posted on Apr 03, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
Error E09 on Siemens dishwasher
There is nothing you can do yourself so contact an authorised repairer. There is a fault in one of the sensors.
Feb 09, 2013 | Dishwashers
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDS5040BB Black Semi-Integrated Dishwasher LDS5040 Logo
62 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
