How do I run mu A/C blower with my furnace being used to help circulate the air
Want to run my ac blower at the same time I run my furnace
    Master:
  • 560 Answers
Put the switch on the thermostat on, "Fan"
Posted on Nov 15, 2014
  • 49 Answers
SOURCE: intertherm furnace
That is a stack limit switch. You are not venting properly. Is your unit power ventilated or gravity fed?
Posted on Nov 28, 2007
  • 230 Answers
SOURCE: blower motor in home air conditioner does not work
The most common failure for this problem is either the start/run capacitor or the fan motor. IF YOU ARE NOT experienced with electricity then I would strongly suggest hiring a technician. The volts are 220 with a potential of 50 amps in a common residential unit.
If you are knowledgeable in this area then make sure the motor has volts to it. If it does have volts and does not spin, it is bad. You can sometimes tell by feeling the motor it will probably be very hot. The compressor will eventually shut itself off when it over heats. It usually will restart after it cools down(sometimes many hours). The motor and capacitor are pretty generic and can be matched up at a local Grainger store or whatever Retail, specialty store that you have in your area.
I hope this helps:)
Posted on Jun 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Posted on Mar 11, 2009
co7196
  • 3433 Answers
SOURCE: AC unit turns on blower doesn't come on
The thermostat is the controller.
Posted on Jun 19, 2009
SOURCE: Furnace comes on for 1 min then kicks off, repeats this cycle
MY FURNACE WOULD RUN FOR ABOUT TWO MINUTES , THEN THE BURNER WOULD GO OUT BUT THE BLOWER WOULD CONTINUE TO RUN , LONG ENOUGH TO COOL THE FAN LIMIT SWITCH DOWN , THEN IT WOULD START THE PROCESS ALL OVER. WHAT FIXED MY PROBLEM WAS THE SECONDARY HEAT EXCHANGER THAT IS LOCATED JUST ABOVE MY BLOWER MOTOR WAS PLUGGED WITH DIRT , WHICH RESTRICTED THE AIR FLOW , CAUSING THE FAN LIMIT SWITCH TO REACH 200 DEGREES AND SHUT THE BURNER DOWN . YOU'LL HAVE TO TAKE THE BLOWER MOTOR OUT TO GET TO IT , BUT MY FURNACE IS RUNNING PERFECT NOW
Posted on Jan 11, 2010
How to turn air conditioner on
The AC typically uses the same blower as the heater to circulate the cool air. Sounds like it is working properly just turn it to cool rather than heat.
Oct 17, 2014 | Palomino 2013 Puma 30-DBSS
I have a Heil furnace (Temp star 9000 I believe) model number NUGS075BG03 that is not working properly. The inducer motor runs fine and I can see a blue flame through the sight glass but the circulating...
you need to check to see if blower motor runs in ac mode, if not then the first thing you want to check is the capaciter for that motor. if capaciter is good, motor may be locked up, you can check the amps of the motor by putting an amp clamp around wires going to blower motor, all ratings should be listed on motor
Oct 17, 2013 | Carrier Icp Heil Tempstar Furnace Blower...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Smell fumes like exhaust when furnace comes on
You really, really need to get your furnace checked by an HVAC (Heating, Ventilation and Air Conditioning) expert. Your furnace has a section where the fire heats tubes that air is blown across then out to your home to heat it. The air in your home and the air from the combustion process should never mix. If you smell exhaust, it's possible there is a breakdown in this part of the furnace and exhaust, which can include carbon monoxide, could be pulled into the air stream and be circulated in your home. Carbon monoxide can and will make you go to sleep and not wake up! Do not use the furnace until you get it checked.
Feb 08, 2013 | Goodman Furnace Draft Inducer Blower ...
When the AC cuts off the blower fan runs for 90 more seconds, I have a Honeywell RTH8500D thermostat, I really don't like that, I live in Texas where the AC runs all the time.
Hello, usually tne blower runs longer to get all the cold air out of the air ducts, same thing happens in heating evcept it's warm air. You can change the blower timing by adjusting it on the integrated control board, it will say blower off timeing, this is what you use to adjust the blower timing. However, 90 sec is the least the blower will run on most furnaces.
May 24, 2011 | Heating & Cooling
Miller furnace model M3RL080 BW, code flashes open limit switch or external load on W, I bought a new limit switch, the furnace runs for 5-10 minutes then the flame goes out, the blower keeps running and...
Check your furnace filter any Limit fault code usually relates to airflow...Not enough...causes the furnace to run too hot and shut off....the furnace can be too big for your house if its new...the ductwork can be too small , also make sure your return air vents are clean and unobstructed . Your furnace can be running too long a cycle ....also if you have central air conditioning the coil for the AC in the Furnace can be dirty...restricting airflow...if all this seems ok you can usually increase the fan speed or try tunning the fan in the "On" position on your thermostat this will promote better circulation
Oct 25, 2009 | Heating & Cooling
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
