Question about Oki Brand Oki MC561 MFP Multifunction Laser Printer Copy/Fax/Print/Scan
Oki Colour Laser Printer Fuser Reset
HI, A page has wrapped around a new fuser in my printer. The printer is showing error 980. As far as I can see the only way to remove this message is to replace the fuser. I dont want to buy another fuser so I'm wondering if there is a work around for thet fuser like replacing the green 63mA fuse for resetting the Drums in other oki machines. I've opened up the old fuser but I cant see a fuse I can replace. Would anyone have a work around please Thanks
How do I reset fatal error code 980 on C 610
check the fuser unit for paper/media stuck to the orange fuser roller. power off machine and re-install. If that dont work fuser unit must be replaced
May 18, 2014 | OKI C5650n LED Laser Printer
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
Error 980 on OKI C5900 fatal error
First, there is no model C5900. There is a model C5800. On the assumption that you are having this issue with a C5800 then the problem is media wrapped around the fuser. After cooling you can try to unravel or unwind the wrapped media but you may need to replace the fuser.
Jan 20, 2014 | Oki Electric Industry C5900N Led Printer
Error code 980
Media has wrapped around the fuser. After letting it cool you can try to unwind the media but you may need to replace the fuser
Dec 30, 2013 | Oki Electric Industry C530DN Led Printer
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
My printer model is OKI C5600n. On the displey stay message: Call services. 980:Fatal error. Where is a problem ? Whats is possible doing now?
Error 980 means that there is something stuck to the fuser. Check to see if there is something is stuck in the fuser. If you can't clean it out, then you will need to replace it.
Mar 22, 2011 | OKI C5500n Laser Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Oki Brand Oki MC561 MFP Multifunction Laser Printer Copy/Fax/Print/Scan Logo
67 people viewed this question
Top Oki Brand Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Oki Brand Office Equipment and Supply Expert? Answer questions, earn points and help others
